Sony VAIO PCG-3E2L Battery Replacement
    1. Sony VAIO PCG-3E2L Battery Replacement, Battery: step 1, image 1 of 1
      • First, locate the battery compartment found at the top, underneath the machine.
      • Use your thumbs to push the switch locks inward.
      Ask FixBot
    2. Sony VAIO PCG-3E2L Battery Replacement: step 2, image 1 of 1
      • Upon removing the cover you will be met with the current battery.
      • Take note of the orientation of the current battery and carefully locate the lock switch at the middle bottom of the battery and remove it, then set the replacement battery inside the reverse way you removed the old one to install it.
      Ask FixBot
    3. Sony VAIO PCG-3E2L Battery Replacement: step 3, image 1 of 1
      • Replace the battery while holding the lock switches inward to install it securely.
      • Check to make sure the lock switch are back into the lock position and the battery cover is flush with the rest of the laptop frame.
      • Now you are able to safely plug back in your charger to test the battery.
      Ask FixBot
All that is required is for you to power off your laptop and disconnect it from any power source, then flip it around to open the battery cover using the lock switches with both thumbs, then swap the battery in the same orientation and install back the battery cover and secure it with the lock switches before resuming normal operations.
4 other people completed this guide.
Chengyang Chen
970 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 114
All Time: 2,060
