Up to 20% off select tools
Sony ULT WEAR Touch Sensor Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
106
All Time:
887
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
  • Spudger
    4.9
  • Phillips #00 Screwdriver
    4.9
Introduction
Go to step 1 ↓
Having trouble operating the touch controls such as volume, playback, or calls? The sensor might be failing and may need to be replaced. Follow this simple guide to replace the touch sensor connected to the mainboard via a ribbon cable in your Sony ULT Wear.
Before replacing the sensor, make sure the surface of it is clean. Oil, dirt, or residue can interfere with conductivity if overlooked and create false unresponsiveness. Also, make sure the problem is not a loose connection by applying light pressure to the housing. Before you begin, power device off to protect yourself and circuit components.
    1. Sony ULT WEAR Touch Sensor Replacement, Touch Sensor: step 1, image 1 of 3 Sony ULT WEAR Touch Sensor Replacement, Touch Sensor: step 1, image 2 of 3 Sony ULT WEAR Touch Sensor Replacement, Touch Sensor: step 1, image 3 of 3
      • Remove the right ear pad by gently prying it open with the spudger.
      • Remove the eight 4.3 mm screws on the driver.
      Ask FixBot
    2. Sony ULT WEAR Touch Sensor Replacement: step 2, image 1 of 3 Sony ULT WEAR Touch Sensor Replacement: step 2, image 2 of 3 Sony ULT WEAR Touch Sensor Replacement: step 2, image 3 of 3
      • Flip over the right ear pad to expose the outer shell.
      • Carefully pry the outer shell with the plastic spudger, making sure to keep the ribbon cable intact.
      • Disconnect the ribbon cable from the board.
      • The sensor is attached to the outer shell, from here the sensor can be replaced.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Michelle Pride
737 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 106
All Time: 887
