Sony ULT WEAR Battery Replacement
    1. Sony ULT WEAR Battery Replacement, Battery: step 1, image 1 of 3 Sony ULT WEAR Battery Replacement, Battery: step 1, image 2 of 3 Sony ULT WEAR Battery Replacement, Battery: step 1, image 3 of 3
      • Remove the ear cushion carefully from the right can.
      • Only remove the four screws from the center of the can using a Phillips #00 screwdriver.
      Ask FixBot
    2. Sony ULT WEAR Battery Replacement: step 2, image 1 of 3 Sony ULT WEAR Battery Replacement: step 2, image 2 of 3 Sony ULT WEAR Battery Replacement: step 2, image 3 of 3
      • Flip the right cuff of the headphones so the can lays flat.
      • Take your spudger and carefully pry the cover off.
      • When removing the cover, do not pull roughly as this can damage the ribbon cable connecting the cover to the rest of the can.
      • Use your tweezers to lift the small black ZIF locking flap and disconnect the ribbon cable.
      Ask FixBot
    3. Sony ULT WEAR Battery Replacement: step 3, image 1 of 3 Sony ULT WEAR Battery Replacement: step 3, image 2 of 3 Sony ULT WEAR Battery Replacement: step 3, image 3 of 3
      • Use tweezers to pull the white battery connector directly out of its socket.
      • Use a hairdryer to lightly heat the battery.
      • Place the flat end of a spudger under the battery to pry it slowly off the adhesive.
      • Take care not to bend or puncture the battery.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 46
Past 30 Days: 177
All Time: 1,879
