Introduction
Go to step 1 ↓This part connects the device to the internet so that it can receive software updates from Sony and so that the owner can access their desired streaming services and use the Blu ray player as multi-media device,
Please follow the top cover and front panel removal as this card is located right under the both those panels in the center of the device.
Tools
Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
Slide both covers back about a 1/2 inch, then pull them away from the case.
Toward the panel there is a ribbon cable with 4 small black pieces of tape holding it down
Pull directly up on the ribbon cable to disconnect it from the motherboard
Gently pull the cable back away from the motherboard pulling the tape off with it
Disconnect the power connection by pulling it straight back and out of the card.
