Up to 20% off select tools
Sony UBP-UX80 Button PCB Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
69
All Time:
534
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This part has the buttons which controls the device power and the ejecting of the disc tray in order to place in or remove a disc. this part also has a USB port to have a wired connection with another device. This is mounted to the inside of the front panel.
Be careful when removing the screws because it it easy to strip plastic treads so do not force the screws in when reassembling.
    1. Sony UBP-UX80 Button PCB Replacement, Top Cover: step 1, image 1 of 3 Sony UBP-UX80 Button PCB Replacement, Top Cover: step 1, image 2 of 3 Sony UBP-UX80 Button PCB Replacement, Top Cover: step 1, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
      • Slide both covers back about a 1/2 inch, then pull them away from the case.
      Ask FixBot
    2. Sony UBP-UX80 Button PCB Replacement: step 2, image 1 of 3 Sony UBP-UX80 Button PCB Replacement: step 2, image 2 of 3 Sony UBP-UX80 Button PCB Replacement: step 2, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
      • Similar to the previous step, it is identical cases on both sides of the device.
      • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
      Ask FixBot
    3. Sony UBP-UX80 Button PCB Replacement: step 3, image 1 of 2 Sony UBP-UX80 Button PCB Replacement: step 3, image 2 of 2
      • Press in the tabs found on the front-sides of the case (connected to the front panel).
      • Slide the top cover forward.
      • Lift off the case.
      Ask FixBot
    4. Sony UBP-UX80 Button PCB Replacement: step 4, image 1 of 3 Sony UBP-UX80 Button PCB Replacement: step 4, image 2 of 3 Sony UBP-UX80 Button PCB Replacement: step 4, image 3 of 3
      • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
      • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
      • Life the back of the cover up and off of the chasis.
      Ask FixBot
    1. Sony UBP-UX80 Button PCB Replacement, Front Cover: step 5, image 1 of 3 Sony UBP-UX80 Button PCB Replacement, Front Cover: step 5, image 2 of 3 Sony UBP-UX80 Button PCB Replacement, Front Cover: step 5, image 3 of 3
      • Toward the panel there is a ribbon cable with 4 small black pieces of tape holding it down
      • Pull directly up on the ribbon cable to disconnect it from the motherboard
      • Gently pull the cable back away from the motherboard pulling the tape off with it
      Ask FixBot
    2. Sony UBP-UX80 Button PCB Replacement: step 6, image 1 of 1
      • Once all pieces of tape have been pulled up, the ribbon cable should look like this.
      Ask FixBot
    3. Sony UBP-UX80 Button PCB Replacement: step 7, image 1 of 2 Sony UBP-UX80 Button PCB Replacement: step 7, image 2 of 2
      • There are screws on every side of the front panel holding it in. Use a #2 Phillips head screwdriver to remove the nine screws.
      • Unscrew the three 10.5 mm long ph #2 screws on the top.
      • Unscrew the four 10.5 mm long ph #2 screws on the bottom.
      Ask FixBot
    4. Sony UBP-UX80 Button PCB Replacement: step 8, image 1 of 2 Sony UBP-UX80 Button PCB Replacement: step 8, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the 10.5 mm screws, one on each side of the device.
      Ask FixBot
    5. Sony UBP-UX80 Button PCB Replacement: step 9, image 1 of 3 Sony UBP-UX80 Button PCB Replacement: step 9, image 2 of 3 Sony UBP-UX80 Button PCB Replacement: step 9, image 3 of 3
      • Lift tab on the left side of the device
      • Work your way right, lifting the next tabs. One on the bottom and one the Top
      • Continue working the tabs on the top and bottom, keeping them from snapping back in place.
      Ask FixBot
    6. Sony UBP-UX80 Button PCB Replacement: step 10, image 1 of 1
      • Once all tabs are disconnected, pull the front panel forward to fully disconnect it
      Ask FixBot
    1. Sony UBP-UX80 Button PCB Replacement, Button PCB: step 11, image 1 of 1
      • Once the Front Panel is removed, look to the inside of it and find a green circuit board which will be the Personal Control Board (PCB).
      Ask FixBot
    2. Sony UBP-UX80 Button PCB Replacement: step 12, image 1 of 1
      • Remove the four 10mm screws holding the PCB in place and unscrew them using the #2 Phillips head screwdriver.
      Ask FixBot
    3. Sony UBP-UX80 Button PCB Replacement: step 13, image 1 of 2 Sony UBP-UX80 Button PCB Replacement: step 13, image 2 of 2
      • Lift up on the bottom of the silver bracket and pull out to remove the PCB.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Remember to not force the screw into the holes to not strip the threads.
Author
with
Ryan Masoud
193 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 69
All Time: 534
