Introduction
This part allows a persons phone to connect up to the Blu ray player so that they can choose videos, tv shows, and movies from your phone and play them on your television.
This part is very small and is held on by only one screw and a small and fragile wire connecting it. So be cautious and gentle when disassembling and reassembling this part.
Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
Slide both covers back about a 1/2 inch, then pull them away from the case.
Toward the panel there is a ribbon cable with 4 small black pieces of tape holding it down
Pull directly up on the ribbon cable to disconnect it from the motherboard
Gently pull the cable back away from the motherboard pulling the tape off with it
Once you have the front panel removed the Bluetooth card is located on the left side of the device.
