Up to 20% off select tools
Sony Tablet S Front Camera Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
90
All Time:
1,118
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
    1. Sony Tablet S Front Camera Replacement, Battery: step 1, image 1 of 2 Sony Tablet S Front Camera Replacement, Battery: step 1, image 2 of 2
      • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
      • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
      Ask FixBot
    2. Sony Tablet S Front Camera Replacement: step 2, image 1 of 1
      • Remove the two 10mm Phillips #0 screws located under the grips.
      Ask FixBot
    3. Sony Tablet S Front Camera Replacement: step 3, image 1 of 2 Sony Tablet S Front Camera Replacement: step 3, image 2 of 2
      • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
      • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
      Ask FixBot
    4. Sony Tablet S Front Camera Replacement: step 4, image 1 of 1
      • Once the casing is off, remove the nine 5mm Phillips #0 screws shown.
      Ask FixBot
    5. Sony Tablet S Front Camera Replacement: step 5, image 1 of 1
      • Remove the white ribbon cable by pulling the blue tab straight up out of the socket and then peeling up the tape securing it to the tablet.
      • Use caution when removing the cable, as the socket is very fragile.
      Ask FixBot
    6. Sony Tablet S Front Camera Replacement: step 6, image 1 of 1
      • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
      Ask FixBot
    7. Sony Tablet S Front Camera Replacement: step 7, image 1 of 1
      • Slide the bottom grey cover piece away from the body and remove it.
      • If this piece gives resistance, use a spudger on the sides of the tablet to pry it loose.
      Ask FixBot
    8. Sony Tablet S Front Camera Replacement: step 8, image 1 of 1
      • Remove the five 4mm Phillips #000 screws.
      • Remove the two 5mm Phillips #000 screws holding the charger in place.
      Ask FixBot
    9. Sony Tablet S Front Camera Replacement: step 9, image 1 of 3 Sony Tablet S Front Camera Replacement: step 9, image 2 of 3 Sony Tablet S Front Camera Replacement: step 9, image 3 of 3
      • Position the charging port at an angle so you can thread it through the opening as you remove the black plastic cover from the back of the tablet.
      • If the cover is not coming off easily, use a plastic opening tool to pry it loose from the edges of the screen.
      Ask FixBot
    10. Sony Tablet S Front Camera Replacement: step 10, image 1 of 2 Sony Tablet S Front Camera Replacement: step 10, image 2 of 2
      • Use a spudger to lift the zero insertion force connector latch for the long ribbon cable to the right of the battery, then pull the cable loose from its socket.
      Ask FixBot
    11. Sony Tablet S Front Camera Replacement: step 11, image 1 of 1
      • Remove the three 5mm Phillips #0 screws securing the original battery.
      Ask FixBot
    12. Sony Tablet S Front Camera Replacement: step 12, image 1 of 2 Sony Tablet S Front Camera Replacement: step 12, image 2 of 2
      • Use the spudger to pop the battery loose and remove the battery.
      Ask FixBot
    1. Sony Tablet S Front Camera Replacement, Front Camera: step 13, image 1 of 1
      • Remove the single 5mm #0 Philips screw.
      Ask FixBot
    2. Sony Tablet S Front Camera Replacement: step 14, image 1 of 1
      • Remove the camera assembly.
      Ask FixBot
Author
with
Austin Mann
287 Reputation
5 Guides authored
USF Tampa, Team 3-5, Passmore Fall 2016 Member of USF Tampa, Team 3-5, Passmore Fall 2016
USFT-PASSMORE-F16S3G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 90
All Time: 1,118
