Sony TCM-919 Cassette-Corder Microphone Replacement
  1. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove battery Cover: step 1, image 1 of 1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press down firmly and then push the battery door cover open.
    • Remove any batteries.
    Ask FixBot
  2. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Back Casing: step 2, image 1 of 1
    • Remove the 5, 5.95mm screws as indicated in the picture using the Phillips head screwdriver.
    Ask FixBot
  3. Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: step 3, image 1 of 2 Sony TCM-919 Cassette-Corder Microphone Replacement, Desolder Microphone Wires: step 3, image 2 of 2
    • Look to the back of the top cover.
    • Desolder the two wires connected to the mircophone using the soldering station.
    Ask FixBot
  4. Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: step 4, image 1 of 2 Sony TCM-919 Cassette-Corder Microphone Replacement, Remove Microphone: step 4, image 2 of 2
    • Gently remove the rubber top from the two plastic knobs that hold the microphone in place.
    • Remove the microphone by pulling up.
    Ask FixBot
Marygayle Martin
506 Reputation
5 Guides authored
Baylor, Team 4-3, Williams Fall 2014 Member of Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 47
All Time: 776
