Sony TCM-450 Battery Cover Replacement
  1. Sony TCM-450 Battery Cover Replacement, Back Cabinet: step 1, image 1 of 3 Sony TCM-450 Battery Cover Replacement, Back Cabinet: step 1, image 2 of 3 Sony TCM-450 Battery Cover Replacement, Back Cabinet: step 1, image 3 of 3
    • Remove the two 3.5 mm Phillips #00 screws from the bottom of the device.
    • Caution: Ensure the device is off and unplugged if using the power adapter, as it is unsafe to remove the cabinet while on and will cause damage and potential harm to the user.
    Ask FixBot
  2. Sony TCM-450 Battery Cover Replacement: step 2, image 1 of 3 Sony TCM-450 Battery Cover Replacement: step 2, image 2 of 3 Sony TCM-450 Battery Cover Replacement: step 2, image 3 of 3
    • Open the lid, and carefully remove the two 9.7 mm Phillips #0 screws from the inside of the front cabinet.
    • Exercise caution while removing these screws, as damage to essential parts may occur and other minor damages may occur if the screwdriver slips.
    Ask FixBot
  3. Sony TCM-450 Battery Cover Replacement: step 3, image 1 of 3 Sony TCM-450 Battery Cover Replacement: step 3, image 2 of 3 Sony TCM-450 Battery Cover Replacement: step 3, image 3 of 3
    • Open the battery cover, and gently remove the back cabinet with the iFixit Opening tool.
    • The device will make a popping sound when removing the back cabinet. The back cabinet may feel as if it is not loose. However, as long as the back cabinet looks disconnected from the lid, it is safe to remove.
    Ask FixBot
  4. Sony TCM-450 Battery Cover Replacement, Battery Cover: step 4, image 1 of 3 Sony TCM-450 Battery Cover Replacement, Battery Cover: step 4, image 2 of 3 Sony TCM-450 Battery Cover Replacement, Battery Cover: step 4, image 3 of 3
    • Carefully remove the three inner screws as shown from the circuit board to loosen it.
    • Remove the following screws in this order:
    • A 3.4 mm Phillips #00
    • A 4.6 mm Phillips #00
    • A 9.7 mm Phillips #0
    Ask FixBot
  5. Sony TCM-450 Battery Cover Replacement: step 5, image 1 of 2 Sony TCM-450 Battery Cover Replacement: step 5, image 2 of 2
    • Carefully move the gray wire out of its slot on the circuit board before continuing.
    Ask FixBot
  6. Sony TCM-450 Battery Cover Replacement: step 6, image 1 of 3 Sony TCM-450 Battery Cover Replacement: step 6, image 2 of 3 Sony TCM-450 Battery Cover Replacement: step 6, image 3 of 3
    • Gently lift the circuit board and gently slide the battery cover down off of the hinge pin as shown.
    • Caution: Do not lift the circuit board too high or wires will be torn and damaged.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 339
