Sony TC-WE825S Power Button Replacement
    1. Sony TC-WE825S Power Button Replacement, Power Button: step 1, image 1 of 3 Sony TC-WE825S Power Button Replacement, Power Button: step 1, image 2 of 3 Sony TC-WE825S Power Button Replacement, Power Button: step 1, image 3 of 3
      • Unscrew the 8mm Phillips head screws from the left and right sides of the cassette player.
      Ask FixBot
    2. Sony TC-WE825S Power Button Replacement: step 2, image 1 of 3 Sony TC-WE825S Power Button Replacement: step 2, image 2 of 3 Sony TC-WE825S Power Button Replacement: step 2, image 3 of 3
      • Unscrew the 8mm Phillips head screw from the back of the cassette panel. Remove the cover.
      Ask FixBot
    3. Sony TC-WE825S Power Button Replacement: step 3, image 1 of 3 Sony TC-WE825S Power Button Replacement: step 3, image 2 of 3 Sony TC-WE825S Power Button Replacement: step 3, image 3 of 3
      • Locate the power cord connection and disconnect it. To remove it, press down on the plastic tab and slowly slide it out of the socket.
      Ask FixBot
    4. Sony TC-WE825S Power Button Replacement: step 4, image 1 of 2 Sony TC-WE825S Power Button Replacement: step 4, image 2 of 2
      • Locate the cords that are connected to the power button. Remove the connection by tugging on the cords gently, releasing them from the main PC board.
      Ask FixBot
    5. Sony TC-WE825S Power Button Replacement: step 5, image 1 of 1
      • Unscrew all five 7.5mm Phillips head screws from the PCB (printed circuit board) behind the power switch.
      Ask FixBot
    6. Sony TC-WE825S Power Button Replacement: step 6, image 1 of 1
      • Use forceps to gently pry the PCB from the frame of the cassette player.
      Ask FixBot
    7. Sony TC-WE825S Power Button Replacement: step 7, image 1 of 3 Sony TC-WE825S Power Button Replacement: step 7, image 2 of 3 Sony TC-WE825S Power Button Replacement: step 7, image 3 of 3
      • Use a soldering iron to desolder the power switch’s terminals and connections. Remove the power switch, replace it, and solder it back together. Repeat these steps in reverse order to put the cassette player back together.
      Ask FixBot
Cameron
108 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,061
