Up to 20% off select tools
Sony Smart Watch SW2 Display Assembly Replacement
Views: 4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
112
All Time:
3,958
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
In this guide we will be taking the Sony Smart Watch SW2 watch out of its housing to remove its screen in order to reach the interior components. This process will only require a small tool with a flat edge.
    1. Sony Smart Watch SW2 Display Assembly Replacement, Display Assembly: step 1, image 1 of 1
      • Detach the smart watch from the band by pushing on the back of the watch housing.
      • The power button may fall out once the smart watch is detached.
      • Set aside the power button and watch band as they are no longer needed for further disassembly.
      Ask FixBot
    2. Sony Smart Watch SW2 Display Assembly Replacement: step 2, image 1 of 1
      • Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
      Ask FixBot
    3. Sony Smart Watch SW2 Display Assembly Replacement: step 3, image 1 of 1
      • Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
      Ask FixBot
    4. Sony Smart Watch SW2 Display Assembly Replacement: step 4, image 1 of 1
      • Set aside the detached LCD screen to access the battery.
      Ask FixBot
To reassemble your device, follow these steps in reverse order.
3 other people completed this guide.
Author
with
Vincent Shiue
265 Reputation
2 Guides authored
IUPUI, Team S1-G5, Freund Spring 2018 Member of IUPUI, Team S1-G5, Freund Spring 2018
IUPUI-FREUND-S18S1G5
3 Members
24 Guides authored
1 Guide Comment
whwre can I get the LCD screen for SW2?
faizal ahamed - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 112
All Time: 3,958
