Sony SS-CCP1 Speaker Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
36
Past 30 Days:
145
All Time:
5,385
Comments: 1
1 comment on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will show the steps for removing each speaker from the box and the procedure for removing all wires from the speakers.
Tools
    1. Sony SS-CCP1 Speaker Replacement, Screen: step 1, image 1 of 3 Sony SS-CCP1 Speaker Replacement, Screen: step 1, image 2 of 3 Sony SS-CCP1 Speaker Replacement, Screen: step 1, image 3 of 3
      • Pull screen cover from the edges for removal. This will not require much effort.
      Ask FixBot
    1. Sony SS-CCP1 Speaker Replacement, Speaker: step 2, image 1 of 2 Sony SS-CCP1 Speaker Replacement, Speaker: step 2, image 2 of 2
      • Remove the seven 18.06mm PH1 screws.
      Ask FixBot
    2. Sony SS-CCP1 Speaker Replacement: step 3, image 1 of 3 Sony SS-CCP1 Speaker Replacement: step 3, image 2 of 3 Sony SS-CCP1 Speaker Replacement: step 3, image 3 of 3
      • Remove the crimps from the tweeter speaker.
      • If its not connected too tightly the crimps can be removed by hand pressure only.
      • If its too tight to be removed by hand, then you can use a pair of pliers to removed the crimps.
      • Never remove by pulling on the cables. Always pull by the metal crimps.
      Ask FixBot
    3. Sony SS-CCP1 Speaker Replacement: step 4, image 1 of 3 Sony SS-CCP1 Speaker Replacement: step 4, image 2 of 3 Sony SS-CCP1 Speaker Replacement: step 4, image 3 of 3
      • Remove the crimps from the 12cm loudspeaker.
      Ask FixBot
    4. Sony SS-CCP1 Speaker Replacement: step 5, image 1 of 2 Sony SS-CCP1 Speaker Replacement: step 5, image 2 of 2
      • Remove the grommet using an object with a flat edge.
      • The grommet is not made of rubber, it is made of plastic. Be careful when removing it, as it can break easily.
      Ask FixBot
    5. Sony SS-CCP1 Speaker Replacement: step 6, image 1 of 2 Sony SS-CCP1 Speaker Replacement: step 6, image 2 of 2
      • Feed the speaker cable through the front of the box.
      Ask FixBot
7 other people completed this guide.
Dallas
1,036 Reputation
3 Guides authored
IUPUI, Team 3-2, Baechle Fall 2016 Member of IUPUI, Team 3-2, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G2
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 36
Past 30 Days: 145
All Time: 5,385
