Sony SRS-XG300 Battery Replacement
  1. Sony SRS-XG300 Battery Replacement, Fabric Cover: step 1, image 1 of 3 Sony SRS-XG300 Battery Replacement, Fabric Cover: step 1, image 2 of 3 Sony SRS-XG300 Battery Replacement, Fabric Cover: step 1, image 3 of 3
    • Before beginning, make sure to unplug and power off your speaker.
    • With the Sony label on the left, roll the speaker horizontally to the bottom of the speaker with the rubber stands.
    • Remove four 12 mm screws with a Phillips #1 screwdriver.
    • Remove the loose rubber feet.
    Ask FixBot
  2. Sony SRS-XG300 Battery Replacement: step 2, image 1 of 2 Sony SRS-XG300 Battery Replacement: step 2, image 2 of 2
    • Insert the metal spudger tool at 90-degree angle into the right part of seam.
    • Pry off the top part of the fabric cover using the metal spudger.
    • Follow the seam to completely detach the top part of the fabric cover.
    • Repeat to remove the bottom part of the fabric cover.
    Ask FixBot
  3. Sony SRS-XG300 Battery Replacement, Tweeter: step 3, image 1 of 1
    • Unclip all six trapezoid-shaped notches around the rim of the speaker using the metal spudger.
    • Begin at the end of the speaker volume button board for an easier process.
    • You may have to work clips off, pushing away from the speaker simultaneously.
    • Remove the speaker mounting ring.
    • Repeat the same steps on the other end of the speaker with the power button board.
    Ask FixBot
  4. Sony SRS-XG300 Battery Replacement: step 4, image 1 of 3 Sony SRS-XG300 Battery Replacement: step 4, image 2 of 3 Sony SRS-XG300 Battery Replacement: step 4, image 3 of 3
    • Remove the four 12 mm screws on the corners of each tweeter using the Phillips #1 screwdriver.
    • The tweeters are smaller compared to the two woofers in the center of the speaker.
    Ask FixBot
  5. Sony SRS-XG300 Battery Replacement: step 5, image 1 of 2 Sony SRS-XG300 Battery Replacement: step 5, image 2 of 2
    • Lift the right tweeter up to expose the connected cables at the top and bottom of the right tweeter.
    • Pinch down on the metal tab and pull outward to disconnect each cable.
    • Pieces are malleable, so you may have to maneuver to disconnect.
    • Lift the right tweeter up and out of the case.
    Ask FixBot
  6. Sony SRS-XG300 Battery Replacement: step 6, image 1 of 3 Sony SRS-XG300 Battery Replacement: step 6, image 2 of 3 Sony SRS-XG300 Battery Replacement: step 6, image 3 of 3
    • Remove the six 12 mm screws on the rim of the radiator using the Phillips #1 screwdriver.
    • Uncap the left bass radiator. Detach the blue ribbon cable from the bass radiator.
    • Using the angled tweezers will make this process easier.
    • Remove the left bass radiator.
    Ask FixBot
  7. Sony SRS-XG300 Battery Replacement: step 7, image 1 of 2 Sony SRS-XG300 Battery Replacement: step 7, image 2 of 2
    • Disconnect the microphone by pulling on the white end of the microphone cable.
    Ask FixBot
  8. Sony SRS-XG300 Battery Replacement: step 8, image 1 of 2 Sony SRS-XG300 Battery Replacement: step 8, image 2 of 2
    • Lift the left tweeter up to expose the connected cables at the top and bottom of the left tweeter.
    • Lift the left tweeter up and out of the case.
    Ask FixBot
  9. Sony SRS-XG300 Battery Replacement, Woofer: step 9, image 1 of 1
    • Remove eight 12 mm screws on the woofers using a Phillips #1 screwdriver.
    Ask FixBot
  10. Sony SRS-XG300 Battery Replacement: step 10, image 1 of 1
    • Lift the right woofer to expose the two connected cables at the bottom of the right woofer.
    • Disconnect both cables by pinching down on the metal end and pulling outward.
    • Cable ends are malleable, so they may require some maneuvering. Be careful not to damage the wire in the process.
    Ask FixBot
  11. Sony SRS-XG300 Battery Replacement: step 11, image 1 of 1
    • Lift the left woofer to expose the two connected cables at the bottom of the right woofer.
    Ask FixBot
  12. Sony SRS-XG300 Battery Replacement, Battery: step 12, image 1 of 2 Sony SRS-XG300 Battery Replacement, Battery: step 12, image 2 of 2
    • Disconnect the second blue film cable on the left edge of the speaker’s motherboard.
    • If experiencing difficulties with this step, consider using angled tweezers.
    Ask FixBot
  13. Sony SRS-XG300 Battery Replacement: step 13, image 1 of 2 Sony SRS-XG300 Battery Replacement: step 13, image 2 of 2
    • Pull the white end of the left cable cluster to disconnect the set of cables from the motherboard.
    • Be careful to not pull directly on the wires as they are not as durable as the plastic ends.
    Ask FixBot
  14. Sony SRS-XG300 Battery Replacement: step 14, image 1 of 2 Sony SRS-XG300 Battery Replacement: step 14, image 2 of 2
    • Pull the white end of the right cable cluster to disconnect the set of cables from the motherboard.
    Ask FixBot
  15. Sony SRS-XG300 Battery Replacement: step 15, image 1 of 1
    • Remove the six 12 mm screws that attach the motherboard to the base of the speaker using the Phillips #1 screwdriver.
    Ask FixBot
  16. Sony SRS-XG300 Battery Replacement: step 16, image 1 of 2 Sony SRS-XG300 Battery Replacement: step 16, image 2 of 2
    • Remove the two 12 mm screws at the bottom of the battery box using the Phillips #1 screwdriver.
    Ask FixBot
  17. Sony SRS-XG300 Battery Replacement: step 17, image 1 of 2 Sony SRS-XG300 Battery Replacement: step 17, image 2 of 2
    • Use the metal spudger to push in the two bottom clips and release the entire motherboard and battery unit.
    Ask FixBot
  18. Sony SRS-XG300 Battery Replacement: step 18, image 1 of 1
    • Pull the motherboard out.
    • The motherboard should be easy to remove, so do not apply too much force during this step.
    Ask FixBot
  19. Sony SRS-XG300 Battery Replacement: step 19, image 1 of 2 Sony SRS-XG300 Battery Replacement: step 19, image 2 of 2
    • Disconnect the battery cable plug at the top right of corner the motherboard.
    • Pull the white end of the plug to disconnect the battery.
    Ask FixBot
  20. Sony SRS-XG300 Battery Replacement: step 20, image 1 of 3 Sony SRS-XG300 Battery Replacement: step 20, image 2 of 3 Sony SRS-XG300 Battery Replacement: step 20, image 3 of 3
    • Flip the motherboard and battery unit upside-down.
    • Use your hands to pry the battery up and out of the case.
    • Replace with a new battery.
    Ask FixBot
2 other people completed this guide.
Laci
316 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 78
All Time: 1,040
