Sony SRS-XE200 Microphone Replacement
  1. Sony SRS-XE200 Microphone Replacement, Speaker Assembly: step 1, image 1 of 2 Sony SRS-XE200 Microphone Replacement, Speaker Assembly: step 1, image 2 of 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
    Ask FixBot
  2. Sony SRS-XE200 Microphone Replacement: step 2, image 1 of 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
    Ask FixBot
  3. Sony SRS-XE200 Microphone Replacement: step 3, image 1 of 2 Sony SRS-XE200 Microphone Replacement: step 3, image 2 of 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    Ask FixBot
  4. Sony SRS-XE200 Microphone Replacement: step 4, image 1 of 2 Sony SRS-XE200 Microphone Replacement: step 4, image 2 of 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
    Ask FixBot
  5. Sony SRS-XE200 Microphone Replacement, Battery: step 5, image 1 of 3 Sony SRS-XE200 Microphone Replacement, Battery: step 5, image 2 of 3 Sony SRS-XE200 Microphone Replacement, Battery: step 5, image 3 of 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
    Ask FixBot
  6. Sony SRS-XE200 Microphone Replacement: step 6, image 1 of 3 Sony SRS-XE200 Microphone Replacement: step 6, image 2 of 3 Sony SRS-XE200 Microphone Replacement: step 6, image 3 of 3
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
    Ask FixBot
  7. Sony SRS-XE200 Microphone Replacement, Charging Port: step 7, image 1 of 2 Sony SRS-XE200 Microphone Replacement, Charging Port: step 7, image 2 of 2
    • Remove the charging port.
    Ask FixBot
  8. Sony SRS-XE200 Microphone Replacement, Microphone: step 8, image 1 of 3 Sony SRS-XE200 Microphone Replacement, Microphone: step 8, image 2 of 3 Sony SRS-XE200 Microphone Replacement, Microphone: step 8, image 3 of 3
    • Remove the two 0.8 mm screws connecting the motherboard to the microphone with a Phillips #1 screwdriver.
    • Remove the microphone.
    Ask FixBot
  9. Sony SRS-XE200 Microphone Replacement: step 9, image 1 of 1
    Ask FixBot
  10. Sony SRS-XE200 Microphone Replacement: step 10, image 1 of 2 Sony SRS-XE200 Microphone Replacement: step 10, image 2 of 2
    Ask FixBot
  11. Sony SRS-XE200 Microphone Replacement: step 11, image 1 of 3 Sony SRS-XE200 Microphone Replacement: step 11, image 2 of 3 Sony SRS-XE200 Microphone Replacement: step 11, image 3 of 3
    • Remove the microphone from the case of the speaker.
    • Replace the microphone.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 36
All Time: 610
