Sony SRS-XE200 Battery Replacement
  1. Sony SRS-XE200 Battery Replacement, Speaker Assembly: step 1, image 1 of 2 Sony SRS-XE200 Battery Replacement, Speaker Assembly: step 1, image 2 of 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
    Ask FixBot
  2. Sony SRS-XE200 Battery Replacement: step 2, image 1 of 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
    Ask FixBot
  3. Sony SRS-XE200 Battery Replacement: step 3, image 1 of 2 Sony SRS-XE200 Battery Replacement: step 3, image 2 of 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    Ask FixBot
  4. Sony SRS-XE200 Battery Replacement: step 4, image 1 of 2 Sony SRS-XE200 Battery Replacement: step 4, image 2 of 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
    Ask FixBot
  5. Sony SRS-XE200 Battery Replacement, Battery: step 5, image 1 of 3 Sony SRS-XE200 Battery Replacement, Battery: step 5, image 2 of 3 Sony SRS-XE200 Battery Replacement, Battery: step 5, image 3 of 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
    Ask FixBot
  6. Sony SRS-XE200 Battery Replacement: step 6, image 1 of 3 Sony SRS-XE200 Battery Replacement: step 6, image 2 of 3 Sony SRS-XE200 Battery Replacement: step 6, image 3 of 3
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
    Ask FixBot
2 Guide Comments
Thanks what is the replacement battery number?
fred Pope - Reply Share
What is the battery number for the SRS replacement
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 53
All Time: 1,513
