Introduction
Looking to replace the battery in your SRS-XB23. This is the guide for you. Whether your battery won't hold a charge or isn't taking a charge anymore, this guide will show you how to replace it.
Caution: Avoid bending or puncturing the battery. If the battery appears swollen or emits a strange odor, handle it with extreme care during removal. Review the What to do with a swollen battery wiki for guidance before attempting to work with a swollen battery.
Before you begin this repair, ensure your Bluetooth speaker is powered off and disconnected from the charger.
Hold the speaker and insert the flat end of a spudger into the seam next to the end of the rubber button strip.
Use a spudger to release each clip along the seams of the device.
Use a Phillips #1 screwdriver to remove the two 5.0 mm screws holding each end cap in place.
Use the heavy-duty spudger to pry one of the tabs holding the end cap to the speaker body.
Hold the tab up and insert a blue opening pick into the space to keep the retaining clips from reengaging.
Repeat this for each retaining clip, and pull the end caps off the speaker body.
Repeat to remove the other end cap.
Lift the top speaker driver from the device.
Use tweezers to firmly grasp the connector on the end of the speaker cable.
Pull outward while wiggling the tweezers slightly to disconnect the speaker cable from the socket.
Use tweezers to firmly grip the ribbon cable at the bottom of the speaker opening and gently pull it straight out of the socket.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
