Sony SRS-XB21 Battery Replacement
  1. Sony SRS-XB21 Battery Replacement, Grille: step 1, image 1 of 1
    • Turn the speaker off and disconnect any charging cables.
    Ask FixBot
  2. Sony SRS-XB21 Battery Replacement: step 2, image 1 of 2 Sony SRS-XB21 Battery Replacement: step 2, image 2 of 2
    • Gently run an opening tool along the seam where the grille meets the body.
    • Lift the grille off slowly.
    Ask FixBot
  3. Sony SRS-XB21 Battery Replacement, Front Panel Assembly: step 3, image 1 of 2 Sony SRS-XB21 Battery Replacement, Front Panel Assembly: step 3, image 2 of 2
    • Remove the four screws from the corners of each speaker using a Phillips #1 screwdriver.
    • Remove the three screws from each endcap using a Phillips #1 screwdriver.
    Ask FixBot
  4. Sony SRS-XB21 Battery Replacement: step 4, image 1 of 2 Sony SRS-XB21 Battery Replacement: step 4, image 2 of 2
    • Pull up the speaker housing carefully, as there are wires still connected.
    • Disconnect all of the cables connected to the speaker.
    Ask FixBot
  5. Sony SRS-XB21 Battery Replacement: step 5, image 1 of 1
    • Remove the front panel assembly.
    Ask FixBot
  6. Sony SRS-XB21 Battery Replacement, Battery: step 6, image 1 of 1
    • Remove the rubber gasket around the edge of the battery housing.
    Ask FixBot
  7. Sony SRS-XB21 Battery Replacement: step 7, image 1 of 1
    • Remove the six screws from the battery housing using a Phillips screwdriver.
    Ask FixBot
  8. Sony SRS-XB21 Battery Replacement: step 8, image 1 of 1
    • Remove the plastic covering for the motherboard.
    • Unclip and disconnect the ribbon cable connected to the motherboard.
    Ask FixBot
  9. Sony SRS-XB21 Battery Replacement: step 9, image 1 of 3 Sony SRS-XB21 Battery Replacement: step 9, image 2 of 3 Sony SRS-XB21 Battery Replacement: step 9, image 3 of 3
    • Remove the battery housing.
    • Remove the battery from the housing.
    Ask FixBot
Jesus PD
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 47
Past 30 Days: 186
All Time: 895
