Sony SRS-X55 Button Circuit Board Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
103
All Time:
4,051
Comments: 11
7 comments on steps, 4 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
If the controls or indicator LEDs of your Sony SRS-X55 have stopped working, use this guide to replace the speaker's button board.
Tools
    1. Sony SRS-X55 Button Circuit Board Replacement, Battery: step 1, image 1 of 3 Sony SRS-X55 Button Circuit Board Replacement, Battery: step 1, image 2 of 3 Sony SRS-X55 Button Circuit Board Replacement, Battery: step 1, image 3 of 3
      • Remove the six screw covers with a spudger.
      • Remove the six 11 mm Phillips screws from the bottom panel.
      • Remove the bottom panel of the speaker.
      Ask FixBot
    2. Sony SRS-X55 Button Circuit Board Replacement: step 2, image 1 of 1
      • Disconnect the battery cable from the motherboard.
      • Remove the battery.
      Ask FixBot
    1. Sony SRS-X55 Button Circuit Board Replacement, Speaker Panel: step 3, image 1 of 1
      • Remove the speaker grill by pushing on the two tabs in the corners.
      Ask FixBot
    2. Sony SRS-X55 Button Circuit Board Replacement: step 4, image 1 of 1
      • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
      Ask FixBot
    1. Sony SRS-X55 Button Circuit Board Replacement, Button Circuit Board: step 5, image 1 of 1
      • Using the flat side of the metal spudger, apply pressure to underside of the cover to loosen the adhesive and separate the cover from the top of the speaker.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Ask FixBot
    2. Sony SRS-X55 Button Circuit Board Replacement: step 6, image 1 of 1
      • Using the Phillips #00 screwdriver, pull out the three screws keeping the button board in place.
      Ask FixBot
    3. Sony SRS-X55 Button Circuit Board Replacement: step 7, image 1 of 1
      • Remove the button board from the speaker.
      Ask FixBot
3 other people completed this guide.
4 Guide Comments
My touch system has got stuck in audio in and sound mode when i press the switch on button it powers on. But ater that Although I press on the bluetooth pairing button it does not come on and i can use the set only in wired mode from tab to speaker also i cant manually switch off either.I have to let it idle to allow it to switch on on its own. The lights are on but touch is not responding its stuck in audio in and sound mode. Please advice what should I do please. I cant use the speaker in blue tooth mode. Regards ranil
Ranil - Reply Share
Does anyone know if there is a schematic anywhere for the Sony SRS X55? I want to build a battery pack without the charge controller. Just charge 2 individual 18650 batts and put them in
faycoema - Reply Share
I have no idea where to order the button board.
Tee Jay - Reply Share
arvindpande2008 - Reply Share
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 103
All Time: 4,051
