Sony SRS-X3 Battery Replacement
    1. Sony SRS-X3 Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the 6 philips head screws using the PH1 bit.
      Ask FixBot
    2. Sony SRS-X3 Battery Replacement: step 2, image 1 of 1
      • Remove the 3 philips head screws holding in the green circuit board
      Ask FixBot
    3. Sony SRS-X3 Battery Replacement: step 3, image 1 of 1
      • Unclip the battery pack and replace it with another one.
      Ask FixBot
7 other people completed this guide.
4 Guide Comments
Can you give the battery # on this please
Dan Clark - Reply Share
Good instructions. I had one problem when removing the green circuit card. The ribbon cable came out. On mine there was a small black retention bar that I flipped open to allow the ribbon cable to reinsert, then I returned the retention bar back down to secure the ribbon cable in place. It worked fine after that.
Harpo - Reply Share
It would be nice if the article addressed the 6 rubber pads that cover the screws. There doesn't seem to be a way to remove them without damaging them, and you need them in order to use the speaker without it rattling and moving about from vibrations.
Peter Nosko - Reply Share
Where can I find a ribbon wire replacement
jjaviercf - Reply Share
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 96
All Time: 9,300
