Sony SRS-X 41 Battery Replacement
  1. Sony SRS-X 41 Battery Replacement, Speaker Assembly Replacement: step 1, image 1 of 1
    • Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
    Ask FixBot
  2. Sony SRS-X 41 Battery Replacement: step 2, image 1 of 1
    • Remove the four T-8 screws (15 mm long) from the black speaker face.
    Ask FixBot
  3. Sony SRS-X 41 Battery Replacement: step 3, image 1 of 1
    • Pry the two rubber end pieces loose enough to pry off two pieces of the long plastic casing from the speaker body using a metal spudger.
    Ask FixBot
  4. Sony SRS-X 41 Battery Replacement: step 4, image 1 of 1
    • Pry the two remaining rubber pieces of the casing completely away from the body of the speaker with the same metal pry tool.
    Ask FixBot
  5. Sony SRS-X 41 Battery Replacement: step 5, image 1 of 2 Sony SRS-X 41 Battery Replacement: step 5, image 2 of 2
    • Once you have removed the outer blue casing, four T-8 screws (15 mm long) will be revealed on each corner. After removing these screws, simply pull the top part of the speaker way from the body to get the the inner part of the speaker.
    Ask FixBot
  6. Sony SRS-X 41 Battery Replacement: step 6, image 1 of 1
    • Once you have gotten to the internal parts of the speaker, there are seven wires connecting the speaker plate to the body of the speaker. Pinch the release tabs at the top of each of the four main wires to remove them.
    Ask FixBot
  7. Sony SRS-X 41 Battery Replacement: step 7, image 1 of 3 Sony SRS-X 41 Battery Replacement: step 7, image 2 of 3 Sony SRS-X 41 Battery Replacement: step 7, image 3 of 3
    • Simply pull the thin wires on each side to remove them from their attachment points.
    • Remove the final red and black wire by gently pulling it apart.
    • This will ultimately detach the speaker plate from the base.
    Ask FixBot
  8. Sony SRS-X 41 Battery Replacement, Battery: step 8, image 1 of 1
    • Unscrew the PH1 screw at the top of the speaker.
    Ask FixBot
  9. Sony SRS-X 41 Battery Replacement: step 9, image 1 of 1
    • Slide the white protective case out of the speaker.
    Ask FixBot
  10. Sony SRS-X 41 Battery Replacement: step 10, image 1 of 2 Sony SRS-X 41 Battery Replacement: step 10, image 2 of 2
    • Unplug the wire that connects the battery to the motherboard.
    • To remove the battery, peel away the tape that holds the battery in place.
    Ask FixBot
12 other people completed this guide.
12 Guide Comments
Where can I purchase a replacement battery
andrewamenard - Reply Share
Did you find the battery to this
jayrock.jo - Reply Share
Brother you made my day…
I just finish your tutorial…thanks a
Pepe hernandez - Reply Share
Hi Pepe, where do i get the wright Batterie, what was your exact artikel? U cant find the ones mentioned in the manual… Thank you!!
Johannes Tanz - Reply Share
where can i purchase the new battery
ieezy naga - Reply Share
Past 24 Hours: 2
Past 7 Days: 52
Past 30 Days: 225
All Time: 14,637
