Up to 20% off select tools
Sony Reader Touch Edition PRS-600 Power Button Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
93
All Time:
1,399
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
  • Phillips #000 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If the power button on the device is faulty or not working then this guide will show the reader how to replace it.
    1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Back Panel: step 1, image 1 of 1
      • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
      Ask FixBot
    2. Sony Reader Touch Edition PRS-600 Power Button Replacement: step 2, image 1 of 1
      • Slide the back cover off by pushing it to the left, away from the side that held the screws.
      • Remove the cover.
      Ask FixBot
    3. Sony Reader Touch Edition PRS-600 Power Button Replacement: step 3, image 1 of 1
      • This is what the device should look like once the back cover panel has been removed.
      Ask FixBot
    1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Battery: step 4, image 1 of 1
      • Once the back cover has been removed locate the battery in the bottom right corner of the device.
      • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
      Ask FixBot
    2. Sony Reader Touch Edition PRS-600 Power Button Replacement: step 5, image 1 of 1
      • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
      Ask FixBot
    1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Power Button: step 6, image 1 of 1
      • Remove the stylus from the device.
      Ask FixBot
    2. Sony Reader Touch Edition PRS-600 Power Button Replacement: step 7, image 1 of 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: step 7, image 2 of 3 Sony Reader Touch Edition PRS-600 Power Button Replacement: step 7, image 3 of 3
      • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
      • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
      • Pry apart off the top panel of the device.
      Ask FixBot
Author
with
Zachary Jeffers
412 Reputation
4 Guides authored
Clemson, Team 1-4, Benson Fall 2014 Member of Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 93
All Time: 1,399
