Sony Reader Touch Edition PRS-600 Motherboard Replacement
  1. Sony Reader Touch Edition PRS-600 Motherboard Replacement, Back Panel: step 1, image 1 of 1
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
    Ask FixBot
  2. Sony Reader Touch Edition PRS-600 Motherboard Replacement: step 2, image 1 of 1
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
    Ask FixBot
  3. Sony Reader Touch Edition PRS-600 Motherboard Replacement: step 3, image 1 of 1
    • This is what the device should look like once the back cover panel has been removed.
    Ask FixBot
  4. Sony Reader Touch Edition PRS-600 Motherboard Replacement, Battery: step 4, image 1 of 1
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
    Ask FixBot
  5. Sony Reader Touch Edition PRS-600 Motherboard Replacement: step 5, image 1 of 1
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
    Ask FixBot
  6. Sony Reader Touch Edition PRS-600 Motherboard Replacement, Inner Casing: step 6, image 1 of 1
    • Using a screwdriver remove the four 1.4 mm screws that are holding the black plastic casing in place.
    Ask FixBot
  7. Sony Reader Touch Edition PRS-600 Motherboard Replacement: step 7, image 1 of 1
    • Pry open the black casing to access the screw that is holding down the battery holder.
    • Remove the one 1.4 mm screw that is holding down the battery holder located under black casing.
    • Lift the black inner casing and the battery holder out of the device.
    • The battery holder and the black inner casing are connected by a thin strip of copper. There may be glue holding the black inner casing in place.
    Ask FixBot
  8. Sony Reader Touch Edition PRS-600 Motherboard Replacement, Motherboard: step 8, image 1 of 1
    • Using a Phillips head screwdriver, remove the one 1.4 mm screw holding in the motherboard.
    Ask FixBot
  9. Sony Reader Touch Edition PRS-600 Motherboard Replacement: step 9, image 1 of 2 Sony Reader Touch Edition PRS-600 Motherboard Replacement: step 9, image 2 of 2
    • Using the flat end of the spudger, flip up the 4 latches holding down the thin, orange strips that connect the motherboard to the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports.
    • To disconnect the the screen, audio/AC adapter/micro USB ports, and SD card/PRODuo ports pull each orange slip away from their corresponding latch.
    Ask FixBot
  10. Sony Reader Touch Edition PRS-600 Motherboard Replacement: step 10, image 1 of 2 Sony Reader Touch Edition PRS-600 Motherboard Replacement: step 10, image 2 of 2
    • Lift the end of the motherboard closest to the memory cards and pull out.
    Ask FixBot
Terrika Ngobili
873 Reputation
7 Guides authored
Clemson, Team 1-4, Benson Fall 2014 Member of Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 36
All Time: 1,172
