Sony RM-LVR1 Motherboard Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
79
All Time:
860
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will teach you how to replace your motherboard in your Sony device.
Tools
    1. Sony RM-LVR1 Motherboard Replacement, Battery: step 1, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
      • If the screws strips or is previously stripped, refer to the stripped screw repair guide.
      Ask FixBot
    2. Sony RM-LVR1 Motherboard Replacement: step 2, image 1 of 1
      • Battery is the rectangular and silver object in the center of device.
      • Remove battery with finger by prying at the rear.
      • If unable to remove battery, pry out using spudger.
      Ask FixBot
    1. Sony RM-LVR1 Motherboard Replacement, LCD Screen: step 3, image 1 of 2 Sony RM-LVR1 Motherboard Replacement, LCD Screen: step 3, image 2 of 2
      • Unscrew the 3 (three) screws holding the bracket in place.
      • Then remove the bracket by prying one end up.
      • Do not rip the ribbon cable connecting the bracket to the motherboard.
      Ask FixBot
    2. Sony RM-LVR1 Motherboard Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • With tweezers, unplug the ribbon cable from the white connector.
      Ask FixBot
    3. Sony RM-LVR1 Motherboard Replacement: step 5, image 1 of 1
      • Remove motherboard from the device by pulling upward gently, with fingers or tweezers.
      Ask FixBot
    4. Sony RM-LVR1 Motherboard Replacement: step 6, image 1 of 1
      • Gently push out on these two clips holding the LCD to the motherboard
      • Once you have the first two off, ever so carefully, push the LCD towards the remaining two clips.
      • There is a ribbon cable underneath the LCD connecting it to the motherboard. Avoid sharp, sudden movements to prevent it from being damged
      Ask FixBot
    5. Sony RM-LVR1 Motherboard Replacement: step 7, image 1 of 2 Sony RM-LVR1 Motherboard Replacement: step 7, image 2 of 2
      • Undo the ribbon cable attached between the motherboard and screen by prying up black tab which holds the cable, using spudger. (See pictures)
      Ask FixBot
    6. Sony RM-LVR1 Motherboard Replacement: step 8, image 1 of 1
      • Remove the screen from the motherboard.
      Ask FixBot
1 Guide Comment
Hello
Thank you for your tutorial.
My question is about the rubber cap of the push button
Can it be changed? Spare part ?
Regards
gilbert keiser - Reply Share
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 79
All Time: 860
