Sony RDR HX750 HX950 Disassembly
  1. Sony RDR HX750 HX950 Disassembly, Remove cover: step 1, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove cover: step 1, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove cover: step 1, image 3 of 3
    • Remove the screws from the back and sides of the top cover.
    Ask FixBot
  2. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: step 2, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: step 2, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: step 2, image 3 of 3
    • Remove the four screws that secure the hard drive mounting bracket to the bottom of the unit.
    • Unplug the two cables from the rear of the hard drive.
    • Remove the four screws from the bottom of the hard drive mounting bracket.
    Ask FixBot
  3. Sony RDR HX750 HX950 Disassembly, Remove DVD player: step 3, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: step 3, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove DVD player: step 3, image 3 of 3
    • Remove the screws from the DVD cover
    • Remove the screws from the plastic cable holder
    Ask FixBot
  4. Sony RDR HX750 HX950 Disassembly, Remove front Panel: step 4, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: step 4, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove front Panel: step 4, image 3 of 3
    • Insert the paper under each "click" to remove the front panel.
    • Once each "click" is loose, push the front panel gently.
    • The table of the compact disk has a little plastic piece in front that goes up to come out with a "click"
    Ask FixBot
  5. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: step 5, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: step 5, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove  DVD block: step 5, image 3 of 3
    • Unplug the cables show in photo.
    • Disconnect the cable hidden on the side.
    • Remove the piece on the cd reader
    Ask FixBot
  6. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: step 6, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: step 6, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: step 6, image 3 of 3
    • Under the DVD block, remove the screws as shown.
    • Remove the screws on the board.
    • Now the laser can be accessed.
    Ask FixBot
  7. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: step 7, image 1 of 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: step 7, image 2 of 3 Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: step 7, image 3 of 3
    • Inserir instruções aqui.
    Ask FixBot
To open this dvd recorder folow this tutorial
2 other people completed this guide.
Cafony
687 Reputation
4 Guides authored
1 Guide Comment
Hello,HX950 work only with hdd 250Gb,or another,with 500 or 1000Gb ???
Cornelus - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 90
All Time: 7,022
