Sony Pulse Elite Edition Battery Replacement
Views: 15K
View statistics:
Past 24 Hours:
11
Past 7 Days:
44
Past 30 Days:
257
All Time:
14,796
Comments: 9
1 comment on steps, 8 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
When working with electrical components, be sure to avoid loose wires.
Tools
    1. Sony Pulse Elite Edition Battery Replacement, Identifying Earpiece: step 1, image 1 of 1
      • Locate the left side designation on the headband-earpiece junction.
      • The battery is in the right earpiece.
      • The motherboard is in the left earpiece.
      Ask FixBot
    2. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: step 2, image 1 of 2 Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: step 2, image 2 of 2
      • Gently pull around the perimeter of the left ear cushion until it comes off.
      Ask FixBot
    3. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: step 3, image 1 of 2 Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: step 3, image 2 of 2
      • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
      • Gently pull the outer ear rim off of the headset assembly.
      • Harsh removal may cause permanent damage to the speaker wires.
      Ask FixBot
    4. Sony Pulse Elite Edition Battery Replacement, Remove Speaker Housing: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, gently pry the red and black speaker wires from the attached socket.
      Ask FixBot
    1. Sony Pulse Elite Edition Battery Replacement, Remove Battery: step 5, image 1 of 2 Sony Pulse Elite Edition Battery Replacement, Remove Battery: step 5, image 2 of 2
      Buy
      • Lift up battery and disconnect wires using tweezers.
      • Use a new battery for reconstruction.
      Ask FixBot
8 other people completed this guide.
Chris Echter
871 Reputation
4 Guides authored
8 Guide Comments
Where can I buy the replacement battery for this?
Pretty hard to find...
francisklalumiere - Reply Share
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
David McAndrews - Reply Share
Can I mod and replace the battery with a bigger one with no white connection, just positive and negative? Thanks!
marit - Reply Share
Thank you so much for this guide. I got a 1000mAh batter from Amazon for 10 dollars. It lasts way longer and was extremely easy to install. Very thankful for this. Thanks!
sharku19z - Reply Share
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
Garrett Parmenter - Reply Share
Past 24 Hours: 11
Past 7 Days: 44
Past 30 Days: 257
All Time: 14,796
