Up to 20% off select tools
Sony PlayStation Camera Microphone Array Replacement
Views: 8.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
106
All Time:
8,167
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide will aide you in performing the replacement of the Sony PlayStation Camera's microphone array.
The outer case will scratch easily if the device is not handled with care during the opening process. If the aesthetics don't matter to you, this will not be a problem.
Finding the seam to start the case separation can be difficult. Using a flashlight, or very well lit area, can help to find the seam under the right angle. This can be helpful during this step.
    1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: step 1, image 1 of 2 Sony PlayStation Camera Microphone Array Replacement, Microphone Array: step 1, image 2 of 2
      • Separate the camera from the camera stand to gain access to the bottom of the camera.
      Ask FixBot
    2. Sony PlayStation Camera Microphone Array Replacement: step 2, image 1 of 2 Sony PlayStation Camera Microphone Array Replacement: step 2, image 2 of 2
      • With the PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
      Ask FixBot
    3. Sony PlayStation Camera Microphone Array Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, remove the cap holding the cable grommet in place.
      Ask FixBot
    4. Sony PlayStation Camera Microphone Array Replacement: step 4, image 1 of 1
      • Using the tweezers, remove both poly-carbonate lens coverplates.
      • Lift the coverplates slowly, to ensure they do not crack, or break.
      Ask FixBot
    5. Sony PlayStation Camera Microphone Array Replacement: step 5, image 1 of 2 Sony PlayStation Camera Microphone Array Replacement: step 5, image 2 of 2
      • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
      Ask FixBot
    6. Sony PlayStation Camera Microphone Array Replacement: step 6, image 1 of 1
      • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
      • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
      Ask FixBot
    7. Sony PlayStation Camera Microphone Array Replacement: step 7, image 1 of 2 Sony PlayStation Camera Microphone Array Replacement: step 7, image 2 of 2
      • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
      Ask FixBot
    8. Sony PlayStation Camera Microphone Array Replacement: step 8, image 1 of 3 Sony PlayStation Camera Microphone Array Replacement: step 8, image 2 of 3 Sony PlayStation Camera Microphone Array Replacement: step 8, image 3 of 3
      • Lift the motherboard and frame from the plastic housing.
      • Disconnect the camera cable from the motherboard.
      Ask FixBot
    9. Sony PlayStation Camera Microphone Array Replacement: step 9, image 1 of 2 Sony PlayStation Camera Microphone Array Replacement: step 9, image 2 of 2
      • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
      Ask FixBot
    10. Sony PlayStation Camera Microphone Array Replacement: step 10, image 1 of 2 Sony PlayStation Camera Microphone Array Replacement: step 10, image 2 of 2
      • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
      Ask FixBot
    11. Sony PlayStation Camera Microphone Array Replacement: step 11, image 1 of 3 Sony PlayStation Camera Microphone Array Replacement: step 11, image 2 of 3 Sony PlayStation Camera Microphone Array Replacement: step 11, image 3 of 3
      • Using fine point tweezers, grab hold of each microphone, one at a time, and lift from the plastic frame.
      • Using care to not damage the wires, remove microphone array from the retaining tabs on the plastic frame.
      Ask FixBot
Author
with
Joshua Gates
268 Reputation
2 Guides authored
USF Tampa, Team 5-5, Passmore Spring 2017 Member of USF Tampa, Team 5-5, Passmore Spring 2017
USFT-PASSMORE-S17S5G5
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 106
All Time: 8,167
