Sony PlayStation 3D Display Rear Case Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
33
Past 30 Days:
114
All Time:
3,795
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. Sony PlayStation 3D Display Rear Case Replacement, Rear Case: step 1, image 1 of 2 Sony PlayStation 3D Display Rear Case Replacement, Rear Case: step 1, image 2 of 2
      • Remove the base by pushing in the button and sliding out the unit.
      Ask FixBot
    2. Sony PlayStation 3D Display Rear Case Replacement: step 2, image 1 of 3 Sony PlayStation 3D Display Rear Case Replacement: step 2, image 2 of 3 Sony PlayStation 3D Display Rear Case Replacement: step 2, image 3 of 3
      • Remove USB port cover from back plate with a metal spudger.
      • This will prevent the cover from falling under the back plate once it is removed.
      Ask FixBot
    3. Sony PlayStation 3D Display Rear Case Replacement: step 3, image 1 of 2 Sony PlayStation 3D Display Rear Case Replacement: step 3, image 2 of 2
      • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
      • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
      • These screws have different threads and need to be kept separate.
      Ask FixBot
    4. Sony PlayStation 3D Display Rear Case Replacement: step 4, image 1 of 3 Sony PlayStation 3D Display Rear Case Replacement: step 4, image 2 of 3 Sony PlayStation 3D Display Rear Case Replacement: step 4, image 3 of 3
      • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
      • Be gentle to avoid breaking the plastic clips which hold the plate.
      • Once separated the plate easily lifts off.
      Ask FixBot
4 other people completed this guide.
Tia McNaughton
379 Reputation
3 Guides authored
Cal Poly, Team 12-16, Maness Fall 2015 Member of Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Members
72 Guides authored
1 Guide Comment
I got a used display that for some reason came with no screws on the back panel. Can you tell me exactly what type those 6x6mm and 6x8mm screws are? Especially wary since you said the thread sizes are different
Kodi Taylor - Reply Share
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 114
All Time: 3,795
