Sony PlayStation 3D Display Indicator Light Bar Replacement
    1. Sony PlayStation 3D Display Indicator Light Bar Replacement, Rear Case: step 1, image 1 of 2 Sony PlayStation 3D Display Indicator Light Bar Replacement, Rear Case: step 1, image 2 of 2
      • Remove the base by pushing in the button and sliding out the unit.
      Ask FixBot
    2. Sony PlayStation 3D Display Indicator Light Bar Replacement: step 2, image 1 of 3 Sony PlayStation 3D Display Indicator Light Bar Replacement: step 2, image 2 of 3 Sony PlayStation 3D Display Indicator Light Bar Replacement: step 2, image 3 of 3
      • Remove USB port cover from back plate with a metal spudger.
      • This will prevent the cover from falling under the back plate once it is removed.
      Ask FixBot
    3. Sony PlayStation 3D Display Indicator Light Bar Replacement: step 3, image 1 of 2 Sony PlayStation 3D Display Indicator Light Bar Replacement: step 3, image 2 of 2
      • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
      • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
      • These screws have different threads and need to be kept separate.
      Ask FixBot
    4. Sony PlayStation 3D Display Indicator Light Bar Replacement: step 4, image 1 of 3 Sony PlayStation 3D Display Indicator Light Bar Replacement: step 4, image 2 of 3 Sony PlayStation 3D Display Indicator Light Bar Replacement: step 4, image 3 of 3
      • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
      • Be gentle to avoid breaking the plastic clips which hold the plate.
      • Once separated the plate easily lifts off.
      Ask FixBot
    1. Sony PlayStation 3D Display Indicator Light Bar Replacement, Indicator Light Bar: step 5, image 1 of 3 Sony PlayStation 3D Display Indicator Light Bar Replacement, Indicator Light Bar: step 5, image 2 of 3 Sony PlayStation 3D Display Indicator Light Bar Replacement, Indicator Light Bar: step 5, image 3 of 3
      • With the Phillips #02 screwdriver, remove the two 5mm length x 5mm head screws located on the left and right side of the light bar board.
      Ask FixBot
    2. Sony PlayStation 3D Display Indicator Light Bar Replacement: step 6, image 1 of 2 Sony PlayStation 3D Display Indicator Light Bar Replacement: step 6, image 2 of 2
      • Remove the light bar by depressing the tab on the white data connector.
      Ask FixBot
Kyle Franck
257 Reputation
1 Guide authored
Cal Poly, Team 12-16, Maness Fall 2015 Member of Cal Poly, Team 12-16, Maness Fall 2015
CPSU-MANESS-F15S12G16
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 52
All Time: 1,012
