Sony PS1100 Needle Cartridge Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
105
All Time:
5,795
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
In this guide you will learn how to replace a broken or old needle on a Sony PS1100. The green needle cartridge is one solid component, that must be replaced together. The needle cannot simply be replaced by itself. The Sony VL-30G is the proper cartridge for the PS1100 Record player, and can be found in most record shops.
For More Troubleshooting click the link: Sony PS1100 Troubleshooting
    1. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: step 1, image 1 of 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: step 1, image 2 of 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: step 1, image 3 of 3
      • Place the Arm of the record player into the latch to ensure that it does not move during the needle replacement.
      • The arm must be fully locked into place
      Ask FixBot
    2. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge: step 2, image 1 of 1
      • Firmly grip both sides of the cartridge with your thumb and index fingers.
      • CAREFULLY pull the entire cartridge so that it slides out towards the front of the arm holding the needle.
      Ask FixBot
    3. Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: step 3, image 1 of 2 Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: step 3, image 2 of 2
      • Using the New cartridge (Sony VL-30G) gently slide into the arm of the record player. It will click into place when inserted properly.
      • Be careful not to touch the needle when inserting the cartridge or else you risk breaking the new one.
      Ask FixBot
    4. Sony PS1100 Needle Cartridge Replacement, Test the new needle Cartridge: step 4, image 1 of 1
      • Once the needle clicks into place, test the record player to ensure that the needle works properly.
      Ask FixBot
L Cis
110 Reputation
1 Guide authored
USF Tampa, Team 1-8, Donnelly Fall 2014 Member of USF Tampa, Team 1-8, Donnelly Fall 2014
USFT-DONNELLY-F14S1G8
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 105
All Time: 5,795
