Sony PS-LX300USB Motor Replacement
Views: 4.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
32
Past 30 Days:
134
All Time:
4,859
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
The motor is a big part of having the turntable turn, because it spins the drive belt. Replacing it requires some specialty work such as soldering, because it has some electrical components that need to be connected to a power source. Other than that, everything is pretty simple in replacing the motor.
Parts
Tools
    1. Sony PS-LX300USB Motor Replacement, Dust Cover: step 1, image 1 of 1
      • Turn the turntable around so that the back side is visible.
      Ask FixBot
    2. Sony PS-LX300USB Motor Replacement: step 2, image 1 of 2 Sony PS-LX300USB Motor Replacement: step 2, image 2 of 2
      • Begin by releasing the left latch. Apply downward pressure to the square, black button using a flathead screw driver.
      • Once the latch is released, lift upward.
      • Use your left hand to hold the left side of the dust cover above the latch. This ensures the latch does not reconnect.
      Ask FixBot
    3. Sony PS-LX300USB Motor Replacement: step 3, image 1 of 1
      • Use a flat head screw driver to apply pressure to the black square button on the right side.
      Ask FixBot
    4. Sony PS-LX300USB Motor Replacement: step 4, image 1 of 2 Sony PS-LX300USB Motor Replacement: step 4, image 2 of 2
      • Once both the right and left buttons are released, pull the dust cover upwards.
      • The dust cover is now disconnected and ready for replacement.
      Ask FixBot
    1. Sony PS-LX300USB Motor Replacement, Drive Belt: step 5, image 1 of 2 Sony PS-LX300USB Motor Replacement, Drive Belt: step 5, image 2 of 2
      • Lift the rubber mat, and put it to the side. It should be easy to remove, because it simply rests on a metal platter without anything securing it down.
      Ask FixBot
    2. Sony PS-LX300USB Motor Replacement: step 6, image 1 of 1
      • Turn the platter so that the motor pulley can be seen through one of the two outer holes in the platter.
      • If the drive belt is hooked around the motor pulley, unhook it.
      • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
      Ask FixBot
    3. Sony PS-LX300USB Motor Replacement: step 7, image 1 of 1
      • Grasping the platter by its two inner holes, lift it upwards.
      • Removing the platter may take a small amount of force. If the pulley is unhooked and the tone arm is safely to the side, don’t fear using a small amount of force in lifting the platter.
      • If you haven’t yet unhooked the drive belt, the motor pulley and the belt could sustain damage.
      Ask FixBot
    4. Sony PS-LX300USB Motor Replacement: step 8, image 1 of 2 Sony PS-LX300USB Motor Replacement: step 8, image 2 of 2
      • Peel the drive belt from the inner ridge of the metal platter and put it to the side.
      • Sometimes, the drive belt can fall off the platter during deconstruction. If this is the case, simply take it out of the device wherever it is.
      Ask FixBot
    1. Sony PS-LX300USB Motor Replacement, Motor: step 9, image 1 of 2 Sony PS-LX300USB Motor Replacement, Motor: step 9, image 2 of 2
      • Use a PH2 screwdriver to remove the 8 screws from the bottom cover.
      • Now lift the bottom cover to remove it.
      Ask FixBot
    2. Sony PS-LX300USB Motor Replacement: step 10, image 1 of 1
      • The motor is in the right upper corner area of the turntable, shown in the red square.
      Ask FixBot
    3. Sony PS-LX300USB Motor Replacement: step 11, image 1 of 1
      • Using a solder iron, carefully desolder the wires that are connected to the old motor to be able to remove it. Making sure to pay close attention where each wire is connected.
      • From left to right: Black is all the way to the left. Red is next. White is third. Yellow is all the way to the right.
      • When reassembling, do not forget to solder in the wires in their previous places.
      Ask FixBot
    4. Sony PS-LX300USB Motor Replacement: step 12, image 1 of 1
      • Remove the old motor by turning it counterclockwise, freeing it from its position.
      • When reassembling, place the new motor in by aligning the two screws and turning the motor clockwise to secure it.
      Ask FixBot
Christian Fuentes
116 Reputation
1 Guide authored
Cal Poly, Team S8-G3, Banghart Fall 2017 Member of Cal Poly, Team S8-G3, Banghart Fall 2017
CPSU-BANGHART-F17S8G3
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 134
All Time: 4,859
