Up to 20% off select tools
Sony PRS-505 Volume Button Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
56
All Time:
315
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Have the volume buttons on your Sony PRS-505 become stuck, cracked, or physically fallen out of the main frame? The outer buttons (pushers) can wear out or be accidentally damaged over years of use.
This guide is to specifically to help you locate the volume buttons and replace them. It will only take about 5 minutes. This will allow you to comfortably control your audiobooks or TTS (text-to-speech) functions once again.
Caution: Replacing the outer buttons requires partial disassembly of the device. Since the aged plastic is brittle, use a spudger and work carefully to avoid scratching the surrounding bezel when separating the frame components.
    1. Sony PRS-505 Volume Button Replacement, SD Card: step 1, image 1 of 2 Sony PRS-505 Volume Button Replacement, SD Card: step 1, image 2 of 2
      • Press the SD card inward until it clicks and springs outward.
      • Take the SD card out of the device.
      Ask FixBot
    1. Sony PRS-505 Volume Button Replacement, Volume Button: step 2, image 1 of 2 Sony PRS-505 Volume Button Replacement, Volume Button: step 2, image 2 of 2
      • Remove the stylus.
      • Remove the four 2 mm screws from the back of the device using a Phillips #000 screwdriver.
      • Loosen the screw on the bottom of the device that is in its own little divot using a Phillips #000 screwdriver.
      Ask FixBot
    2. Sony PRS-505 Volume Button Replacement: step 3, image 1 of 1
      • Remove the thin panel on the bottom of the device using an opening tool.
      Ask FixBot
    3. Sony PRS-505 Volume Button Replacement: step 4, image 1 of 3 Sony PRS-505 Volume Button Replacement: step 4, image 2 of 3 Sony PRS-505 Volume Button Replacement: step 4, image 3 of 3
      • Unhook and pop out the volume button from the frame of the bottom panel.
      Ask FixBot
Author
with
DaJean
660 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 56
All Time: 315
