Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓Device no longer charging, or is your computer failing to recognize the SD Card? Frequent plugging and unplugging can cause the USB port to become internally loose or damaged.
This specific guide is a "how-to" when it comes to replacing the USB port in a SONY PRS-505. This repair will restore reliable charging and data synchronization functionality.
Note for All Repairers: This port is typically soldered to the main logic board via several tiny contacts. Precise soldering skills and the proper heating tools are required to complete this procedure successfully.
Press the SD card inward until it clicks and springs outward.
Take the SD card out of the device.
Remove the stylus.
Remove the four 2 mm screws from the back of the device using a Phillips #000 screwdriver.
Loosen the screw on the bottom of the device that is in its own little divot using a Phillips #000 screwdriver.
Disconnect the two ribbon cables: one next to the battery compartment and the other next to the SD card reader.
Remove the black midframe.
