Up to 20% off select tools
Sony PRS-505 Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
10
Past 7 Days:
49
Past 30 Days:
146
All Time:
1,114
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 6 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Even with the Sony PRS-505 being important piece of e-reader history, devices eventually face the end of their battery life.
This guide will show you how to safely get to and replace the battery in the particular device so that you can get back to doing your thing.
Warning: The ribbon cables are very delicate. The clips and screws also securing the enclosure require extra care to prevent breaking. proceed slowly and with patience
    1. Sony PRS-505 Battery Replacement, SD Card: step 1, image 1 of 2 Sony PRS-505 Battery Replacement, SD Card: step 1, image 2 of 2
      • Press the SD card inward until it clicks and springs outward.
      • Take the SD card out of the device.
      Ask FixBot
    1. Sony PRS-505 Battery Replacement, Battery: step 2, image 1 of 2 Sony PRS-505 Battery Replacement, Battery: step 2, image 2 of 2
      • Remove the stylus.
      • Remove the four 2 mm screws from the back of the device using a Phillips #000 screwdriver.
      • Loosen the screw on the bottom of the device that is in its own little divot using a Phillips #000 screwdriver.
      Ask FixBot
    2. Sony PRS-505 Battery Replacement: step 3, image 1 of 2 Sony PRS-505 Battery Replacement: step 3, image 2 of 2
      • Remove the thin panel on the bottom of the device using an opening tool.
      • Use a Phillips #000 screwdriver to remove the three 5 mm screws that are underneath the panel.
      Ask FixBot
    3. Sony PRS-505 Battery Replacement: step 4, image 1 of 2 Sony PRS-505 Battery Replacement: step 4, image 2 of 2
      • Remove the thin top panel using an opening tool.
      • Remove the two metal brackets from the top of the device.
      • They are both silver with a hole.
      Ask FixBot
    4. Sony PRS-505 Battery Replacement: step 5, image 1 of 1
      • Gently but firmly push the inner components of the PRS out towards the top until the ribbon cable is completely exposed and accessible.
      Ask FixBot
    5. Sony PRS-505 Battery Replacement: step 6, image 1 of 1
      • Disconnect the ribbon cable.
      • Carefully continue to push the inner body of the device towards the top until the battery is accessible.
      Ask FixBot
    6. Sony PRS-505 Battery Replacement: step 7, image 1 of 3 Sony PRS-505 Battery Replacement: step 7, image 2 of 3 Sony PRS-505 Battery Replacement: step 7, image 3 of 3
      • Gently pry the battery from its placeholder within the device’s inner body. Disconnect and remove the battery.
      • If the battery won’t come out, remove the entire compartment by removing the two 3 mm screws with a Phillips #000 screwdriver.
      Ask FixBot
Author
with
DaJean
660 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 49
Past 30 Days: 146
All Time: 1,114
