Up to 20% off select tools
Sony NWZ-E473 Back Panel Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
86
All Time:
1,599
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
To complete this Sony NWZ-E473 guide, you will need a screw driver and a prying device. Caution is advised when prying the back panel because permanent damage may occur if done incorrectly.
    1. Sony NWZ-E473 Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
      Ask FixBot
    2. Sony NWZ-E473 Back Panel Replacement: step 2, image 1 of 1
      • Use a plastic opening tool to loosen the bottom portion of device.
      Ask FixBot
    3. Sony NWZ-E473 Back Panel Replacement: step 3, image 1 of 1
      • Use a plastic opening tool to loosen the top panel of the device.
      Ask FixBot
    4. Sony NWZ-E473 Back Panel Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
      Ask FixBot
    5. Sony NWZ-E473 Back Panel Replacement: step 5, image 1 of 3 Sony NWZ-E473 Back Panel Replacement: step 5, image 2 of 3 Sony NWZ-E473 Back Panel Replacement: step 5, image 3 of 3
      • Remove the back plate from the device.
      Ask FixBot
2 other people completed this guide.
Author
with
lamallery
259 Reputation
1 Guide authored
USF Tampa, Team 17-6, Watkins Winter 2015 Member of USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 86
All Time: 1,599
