Sony NWZ-E473 Audio Jack Replacement
    1. Sony NWZ-E473 Audio Jack Replacement, Back Panel: step 1, image 1 of 1
      • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
      Ask FixBot
    2. Sony NWZ-E473 Audio Jack Replacement: step 2, image 1 of 1
      • Use a plastic opening tool to loosen the bottom portion of device.
      Ask FixBot
    3. Sony NWZ-E473 Audio Jack Replacement: step 3, image 1 of 1
      • Use a plastic opening tool to loosen the top panel of the device.
      Ask FixBot
    4. Sony NWZ-E473 Audio Jack Replacement: step 4, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
      Ask FixBot
    5. Sony NWZ-E473 Audio Jack Replacement: step 5, image 1 of 3 Sony NWZ-E473 Audio Jack Replacement: step 5, image 2 of 3 Sony NWZ-E473 Audio Jack Replacement: step 5, image 3 of 3
      • Remove the back plate from the device.
      Ask FixBot
    1. Sony NWZ-E473 Audio Jack Replacement, Audio Jack: step 6, image 1 of 1
      • Unscrew one 2.5 mm screw using a Phillips #00 screwdriver on bottom right portion of device located near audio jack.
      Ask FixBot
    2. Sony NWZ-E473 Audio Jack Replacement: step 7, image 1 of 2 Sony NWZ-E473 Audio Jack Replacement: step 7, image 2 of 2
      • Disconnect the headphone jack connection from the motherboard using any tool to remove black audio piece that needs to be replaced.
      Ask FixBot
Chaz
125 Reputation
1 Guide authored
USF Tampa, Team 17-6, Watkins Winter 2015 Member of USF Tampa, Team 17-6, Watkins Winter 2015
USFT-WATKINS-W15S17G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 49
All Time: 1,535
