Up to 20% off select tools
Sony NEX-7 Viewfinder Replacement
Views: 7.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
30
Past 30 Days:
155
All Time:
7,798
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the front and back panels covering the housing of the camera, allowing you to replace the viewfinder. This guide will take time to complete, but the steps are not very difficult to perform.
    1. Sony NEX-7 Viewfinder Replacement, Battery: step 1, image 1 of 2 Sony NEX-7 Viewfinder Replacement, Battery: step 1, image 2 of 2
      • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
      • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
      Ask FixBot
    2. Sony NEX-7 Viewfinder Replacement: step 2, image 1 of 1
      • Flip the camera over such that the power switch points down.
      • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
      Ask FixBot
    3. Sony NEX-7 Viewfinder Replacement: step 3, image 1 of 1
      • With the battery door open, push the blue lever in the battery compartment to release the battery.
      Ask FixBot
    1. Sony NEX-7 Viewfinder Replacement, SD card: step 4, image 1 of 1
      • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
      • Pull the card out with your fingers.
      Ask FixBot
    1. Sony NEX-7 Viewfinder Replacement, Lens: step 5, image 1 of 2 Sony NEX-7 Viewfinder Replacement, Lens: step 5, image 2 of 2
      • First, turn the camera upside down.
      • Press the button located next to silver lens mount and rotate the lens counterclockwise.
      • Pull the lens away from the camera body.
      • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
      Ask FixBot
    1. Sony NEX-7 Viewfinder Replacement, Top and Back Shell: step 6, image 1 of 1
      • Start by removing the two 5/32" #00 screws on the bottom of the camera using the Phillips #00 screwdriver.
      Ask FixBot
    2. Sony NEX-7 Viewfinder Replacement: step 7, image 1 of 2 Sony NEX-7 Viewfinder Replacement: step 7, image 2 of 2
      • Remove the 5/32" #00 screw at the top of the compartment using the Phillips #00 screwdriver.
      • Remove the two 5/32" #00 screws from inside the compartment using the Phillips #00 screwdriver.
      Ask FixBot
    3. Sony NEX-7 Viewfinder Replacement: step 8, image 1 of 2 Sony NEX-7 Viewfinder Replacement: step 8, image 2 of 2
      • Close the battery door by pushing it down until it latches shut.
      Ask FixBot
    4. Sony NEX-7 Viewfinder Replacement: step 9, image 1 of 1
      • Looking at the left side of the camera, lift open the door that has 'HDMI' written on it.
      • Remove the two visible 5/32" #00 screws using the Phillips #00 screwdriver.
      Ask FixBot
    5. Sony NEX-7 Viewfinder Replacement: step 10, image 1 of 3 Sony NEX-7 Viewfinder Replacement: step 10, image 2 of 3 Sony NEX-7 Viewfinder Replacement: step 10, image 3 of 3
      • Looking at the back of the camera, press the button with a lightning bolt on it to pop the flash open.
      • Remove the three 5/32" screws from within the flash compartment using the Phillips #00 screwdriver.
      • Close the flash compartment.
      Ask FixBot
    6. Sony NEX-7 Viewfinder Replacement: step 11, image 1 of 1
      • The top of the camera is attached by three wires and a ribbon cable. Remove the top slowly and gently!
      • Lift the top of the camera off of the body.
      • Let the top hang to the side so you have room to work with the components inside the device.
      Ask FixBot
    7. Sony NEX-7 Viewfinder Replacement: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers or your fingers, gently remove the blue ribbon cable from the port.
      Ask FixBot
    8. Sony NEX-7 Viewfinder Replacement: step 13, image 1 of 2 Sony NEX-7 Viewfinder Replacement: step 13, image 2 of 2
      • Place the tips of your tweezers on either side of the red jack.
      • Gently pull the red plug out of the jack.
      • Repeat those steps for the yellow jack and plug.
      • Now that the top is free, place it aside for later.
      Ask FixBot
    9. Sony NEX-7 Viewfinder Replacement: step 14, image 1 of 1
      • Lift the LCD screen with your fingers such that the screen is bent slightly away from the camera.
      Ask FixBot
    10. Sony NEX-7 Viewfinder Replacement: step 15, image 1 of 3 Sony NEX-7 Viewfinder Replacement: step 15, image 2 of 3 Sony NEX-7 Viewfinder Replacement: step 15, image 3 of 3
      • Starting at the bottom, gently pry the back panel away from the body of the camera using your fingers.
      • Once the back panel is free from the body, rotate the camera such that back is facing you and pull the back panel past the screen by rotating it to fit around the screen.
      • The back panel will be easier to take off if the LCD screen has been extended away from the camera by about 60 degrees.
      • Set the back panel aside.
      Ask FixBot
    1. Sony NEX-7 Viewfinder Replacement, LCD Assembly: step 16, image 1 of 1
      • Remove the two 3/32" #00 screws located next to the viewfinder using the Phillips #00 screwdriver.
      Ask FixBot
    2. Sony NEX-7 Viewfinder Replacement: step 17, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two screws from the right side of the camera below the D ring:
      • The 5/32" upper screw
      • The 3/32" lower screw
      Ask FixBot
    3. Sony NEX-7 Viewfinder Replacement: step 18, image 1 of 1
      • Remove two more 3/32" #00 screws from the bottom of the camera using the Phillips #00 screwdriver.
      Ask FixBot
    4. Sony NEX-7 Viewfinder Replacement: step 19, image 1 of 1
      • Remove two more 3/32" #00 screws from the metal bracket on the left side of the camera using the Phillips #00 screwdriver.
      Ask FixBot
    5. Sony NEX-7 Viewfinder Replacement: step 20, image 1 of 1
      Buy
      • Unplug the orange ribbon cable on the top right of the camera next to the metal bracket by applying tweezers to the tabs on either side of the plug.
      Ask FixBot
    6. Sony NEX-7 Viewfinder Replacement: step 21, image 1 of 1
      • Before pulling off the assembly, fold the rightmost tab of the flexible circuit board away from the metal bracket.
      Ask FixBot
    7. Sony NEX-7 Viewfinder Replacement: step 22, image 1 of 2 Sony NEX-7 Viewfinder Replacement: step 22, image 2 of 2
      • The LCD assembly is attached with a concealed ribbon cable, so be gentle when you remove it.
      • The D ring brackets on either side are not attached, only held in mechanically. Once the LCD assembly starts to come out, they will detach.
      • Pull on the D rings on either side of the camera to start removing the assembly.
      • Once the brackets are cleared from black shell, take them off and set them aside.
      • Continue to remove the screen assembly.
      Ask FixBot
    8. Sony NEX-7 Viewfinder Replacement: step 23, image 1 of 1
      • With the camera face down, move the assembly away from you to get a clear view of the wide ribbon cable.
      • Unplug the cable by applying tweezers to the tabs on either side of the plug.
      • Set the LCD assembly aside.
      Ask FixBot
    1. Sony NEX-7 Viewfinder Replacement, Viewfinder: step 24, image 1 of 1
      Buy
      • Using the tweezers, unhook the flexible circuit board from the metal tab on the right of the viewfinder by rotating it to the left.
      Ask FixBot
    2. Sony NEX-7 Viewfinder Replacement: step 25, image 1 of 1
      • Remove the 5/32" #00 screw next to the back right of the viewfinder using the Phillips #00 screwdriver.
      Ask FixBot
    3. Sony NEX-7 Viewfinder Replacement: step 26, image 1 of 1
      • Using the tweezers lift the black piece of tape from the circuit board below the viewfinder.
      Ask FixBot
    4. Sony NEX-7 Viewfinder Replacement: step 27, image 1 of 1
      • Be gentle when removing the viewfinder because there is an orange ribbon cable connected to the body.
      • Use your fingers to lift the viewfinder from the body.
      Ask FixBot
    5. Sony NEX-7 Viewfinder Replacement: step 28, image 1 of 2 Sony NEX-7 Viewfinder Replacement: step 28, image 2 of 2
      • Use the tweezers to lift the black switch on the white receptacle just below the viewfinder. If properly opened, the ribbon cable will remove with very little force.
      Ask FixBot
    6. Sony NEX-7 Viewfinder Replacement: step 29, image 1 of 1
      • Use your fingers to remove the viewfinder from the camera body.
      Ask FixBot
10 other people completed this guide.
Author
with
Jay Miley
5,540 Reputation
13 Guides authored
Cal Poly, Team 10-55, Amido Spring 2014 Member of Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Members
168 Guides authored
4 Guide Comments
Hello
thank you for this tutorial, can you tell me or buy a replacement viewfinder?
lbasile - Reply Share
ขอบคุณมากสำหรับการแบ่งปันความรู้ ผมเชื่อว่าบทความของคุณจะเป็นประโยชน์มากมายต่อผู้ใช้กล้อง Sony
hs3lri - Reply Share
A very handy set of instructions to have for working on an Next. Someone forced the top cover off the flash/strobe assembly of my Nex7 with their fingernail instead of using the push button. Consequently they damaged the black plastic top cover and broke the small coil spring that keeps the flash/strobe lense pointing forward. Are there any guides to help me remove the damaged assembly in order to fit an OEM replacement assembly? I reside in the UK, and the main Sony repair centre informs me that they can't obtain a new strobe/flash assembly. Does anybody know where I could obtain an OEM black top assembly? Are there any high quality direct replacement aftermarket compatible ones (I'm sure the Sony part is manufactured by a supplier to Sony for assembly of the camera) that can be recommended to fit the Nex 7?
Regards,
Sam Ellis
(Scotland, UK)
Sam Ellis - Reply Share
Hi, i want to buy nex7 viewfinder. Where can i find it? Sorry by me english
Nano Lopez - Reply Share
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 155
All Time: 7,798
