Up to 20% off select tools
Sony NEX-7 Screen Replacement
Views: 13K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
155
All Time:
13,019
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to remove and replace the camera's screen. The guide has many steps and will take time to complete, but each step is relatively easy since the guide requires no advanced techniques. Stick to the steps, and you will get through it!
    1. Sony NEX-7 Screen Replacement, Battery: step 1, image 1 of 2 Sony NEX-7 Screen Replacement, Battery: step 1, image 2 of 2
      • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
      • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
      Ask FixBot
    2. Sony NEX-7 Screen Replacement: step 2, image 1 of 1
      • Flip the camera over such that the power switch points down.
      • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
      Ask FixBot
    3. Sony NEX-7 Screen Replacement: step 3, image 1 of 1
      • With the battery door open, push the blue lever in the battery compartment to release the battery.
      Ask FixBot
    1. Sony NEX-7 Screen Replacement, SD card: step 4, image 1 of 1
      • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
      • Pull the card out with your fingers.
      Ask FixBot
    1. Sony NEX-7 Screen Replacement, Lens: step 5, image 1 of 2 Sony NEX-7 Screen Replacement, Lens: step 5, image 2 of 2
      • First, turn the camera upside down.
      • Press the button located next to silver lens mount and rotate the lens counterclockwise.
      • Pull the lens away from the camera body.
      • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
      Ask FixBot
    1. Sony NEX-7 Screen Replacement, Top and Back Shell: step 6, image 1 of 1
      • Start by removing the two 5/32" #00 screws on the bottom of the camera using the Phillips #00 screwdriver.
      Ask FixBot
    2. Sony NEX-7 Screen Replacement: step 7, image 1 of 2 Sony NEX-7 Screen Replacement: step 7, image 2 of 2
      • Remove the 5/32" #00 screw at the top of the compartment using the Phillips #00 screwdriver.
      • Remove the two 5/32" #00 screws from inside the compartment using the Phillips #00 screwdriver.
      Ask FixBot
    3. Sony NEX-7 Screen Replacement: step 8, image 1 of 2 Sony NEX-7 Screen Replacement: step 8, image 2 of 2
      • Close the battery door by pushing it down until it latches shut.
      Ask FixBot
    4. Sony NEX-7 Screen Replacement: step 9, image 1 of 1
      • Looking at the left side of the camera, lift open the door that has 'HDMI' written on it.
      • Remove the two visible 5/32" #00 screws using the Phillips #00 screwdriver.
      Ask FixBot
    5. Sony NEX-7 Screen Replacement: step 10, image 1 of 3 Sony NEX-7 Screen Replacement: step 10, image 2 of 3 Sony NEX-7 Screen Replacement: step 10, image 3 of 3
      • Looking at the back of the camera, press the button with a lightning bolt on it to pop the flash open.
      • Remove the three 5/32" screws from within the flash compartment using the Phillips #00 screwdriver.
      • Close the flash compartment.
      Ask FixBot
    6. Sony NEX-7 Screen Replacement: step 11, image 1 of 1
      • The top of the camera is attached by three wires and a ribbon cable. Remove the top slowly and gently!
      • Lift the top of the camera off of the body.
      • Let the top hang to the side so you have room to work with the components inside the device.
      Ask FixBot
    7. Sony NEX-7 Screen Replacement: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers or your fingers, gently remove the blue ribbon cable from the port.
      Ask FixBot
    8. Sony NEX-7 Screen Replacement: step 13, image 1 of 2 Sony NEX-7 Screen Replacement: step 13, image 2 of 2
      • Place the tips of your tweezers on either side of the red jack.
      • Gently pull the red plug out of the jack.
      • Repeat those steps for the yellow jack and plug.
      • Now that the top is free, place it aside for later.
      Ask FixBot
    9. Sony NEX-7 Screen Replacement: step 14, image 1 of 1
      • Lift the LCD screen with your fingers such that the screen is bent slightly away from the camera.
      Ask FixBot
    10. Sony NEX-7 Screen Replacement: step 15, image 1 of 3 Sony NEX-7 Screen Replacement: step 15, image 2 of 3 Sony NEX-7 Screen Replacement: step 15, image 3 of 3
      • Starting at the bottom, gently pry the back panel away from the body of the camera using your fingers.
      • Once the back panel is free from the body, rotate the camera such that back is facing you and pull the back panel past the screen by rotating it to fit around the screen.
      • The back panel will be easier to take off if the LCD screen has been extended away from the camera by about 60 degrees.
      • Set the back panel aside.
      Ask FixBot
    1. Sony NEX-7 Screen Replacement, LCD Assembly: step 16, image 1 of 1
      • Remove the two 3/32" #00 screws located next to the viewfinder using the Phillips #00 screwdriver.
      Ask FixBot
    2. Sony NEX-7 Screen Replacement: step 17, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the two screws from the right side of the camera below the D ring:
      • The 5/32" upper screw
      • The 3/32" lower screw
      Ask FixBot
    3. Sony NEX-7 Screen Replacement: step 18, image 1 of 1
      • Remove two more 3/32" #00 screws from the bottom of the camera using the Phillips #00 screwdriver.
      Ask FixBot
    4. Sony NEX-7 Screen Replacement: step 19, image 1 of 1
      • Remove two more 3/32" #00 screws from the metal bracket on the left side of the camera using the Phillips #00 screwdriver.
      Ask FixBot
    5. Sony NEX-7 Screen Replacement: step 20, image 1 of 1
      Buy
      • Unplug the orange ribbon cable on the top right of the camera next to the metal bracket by applying tweezers to the tabs on either side of the plug.
      Ask FixBot
    6. Sony NEX-7 Screen Replacement: step 21, image 1 of 1
      • Before pulling off the assembly, fold the rightmost tab of the flexible circuit board away from the metal bracket.
      Ask FixBot
    7. Sony NEX-7 Screen Replacement: step 22, image 1 of 2 Sony NEX-7 Screen Replacement: step 22, image 2 of 2
      • The LCD assembly is attached with a concealed ribbon cable, so be gentle when you remove it.
      • The D ring brackets on either side are not attached, only held in mechanically. Once the LCD assembly starts to come out, they will detach.
      • Pull on the D rings on either side of the camera to start removing the assembly.
      • Once the brackets are cleared from black shell, take them off and set them aside.
      • Continue to remove the screen assembly.
      Ask FixBot
    8. Sony NEX-7 Screen Replacement: step 23, image 1 of 1
      • With the camera face down, move the assembly away from you to get a clear view of the wide ribbon cable.
      • Unplug the cable by applying tweezers to the tabs on either side of the plug.
      • Set the LCD assembly aside.
      Ask FixBot
    1. Sony NEX-7 Screen Replacement, Screen: step 24, image 1 of 2 Sony NEX-7 Screen Replacement, Screen: step 24, image 2 of 2
      • Set aside the camera body, top, and back plate and focus on the LCD assembly.
      • Rotate the screen away from the metal bracket.
      Ask FixBot
    2. Sony NEX-7 Screen Replacement: step 25, image 1 of 2 Sony NEX-7 Screen Replacement: step 25, image 2 of 2
      Buy
      • Use the tweezers to push the tab near the bottom left corner of the panel to release a plastic cover from the back of the panel.
      Ask FixBot
    3. Sony NEX-7 Screen Replacement: step 26, image 1 of 1
      • Turn the assembly around and slide the plastic cover off of the ribbon cable.
      Ask FixBot
    4. Sony NEX-7 Screen Replacement: step 27, image 1 of 1
      • Remove the four 2/32" #00 screws from the metal bracket using the Phillips #00 screwdriver.
      Ask FixBot
    5. Sony NEX-7 Screen Replacement: step 28, image 1 of 2 Sony NEX-7 Screen Replacement: step 28, image 2 of 2
      • Remove the screen from the metal panel.
      Ask FixBot
7 other people completed this guide.
Author
with
Jay Miley
5,540 Reputation
13 Guides authored
Cal Poly, Team 10-55, Amido Spring 2014 Member of Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Members
168 Guides authored
4 Guide Comments
oh oh - took my nex 7 apart - got to step 28 "Conclusion" an realized I need more steps;
how do I disassemble ( and re-assemble )the "screen" that I have now "removes from the metal panel" ?!?
the part I was hopping to replace is part "LCD Screen Display for Sony nex7" a thin panel, dark gray on one side
and mirror-like on the other.....
Is there another how-to out there somewhere on how to do that ?
or did I order a pert that's to detailed/intricate for a how to series ....
Thanks for any advice
john Grigaitis - Reply Share
hey,
where can we buy the the new screen. I want to change the old broken screen of my NEX 7 but i don't know where to buy on screen.
Thanks for the informations.
maxence - Reply Share
A much simpler process for this is to remove the two screws at the bottom of the screen, flip the screen to 90 degrees out from the body, and remove the two screws on the back. Then the top plastic piece can be worked loose and the LCD frame can be removed from the metal bracket.
Reinstallation is a little bit tricky because the plastic piece and the metal back plate much be held in place along with the LCD frame before any of the screws can be reinstalled.
Note that there is a plastic spring piece that clips in the top of the LCD frame, and also a clear/white plastic piece that sits on the light sensor element in the corner of the screen.
Long story short is that the metal LCD hinge does not need to be removed from the body in order to replace the LCD…. so, 4 screws instead of 28.
Paul Chambre - Reply Share
Much easier 4 screw method here:-
https://www.youtube.com/watch?v=jvOcd8NO...
feenix4eva - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 155
All Time: 13,019
