Up to 20% off select tools
Sony NEX-7 Battery Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
127
All Time:
3,273
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this guide to open the battery compartment and replace the battery.
    1. Sony NEX-7 Battery Replacement, Battery: step 1, image 1 of 2 Sony NEX-7 Battery Replacement, Battery: step 1, image 2 of 2
      • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
      • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
      Ask FixBot
    2. Sony NEX-7 Battery Replacement: step 2, image 1 of 1
      • Flip the camera over such that the power switch points down.
      • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
      Ask FixBot
    3. Sony NEX-7 Battery Replacement: step 3, image 1 of 1
      • With the battery door open, push the blue lever in the battery compartment to release the battery.
      Ask FixBot
To replace the battery, fit it in the slot, then close and lock the door.
2 other people completed this guide.
Author
with
Tyler
614 Reputation
1 Guide authored
Cal Poly, Team 10-55, Amido Spring 2014 Member of Cal Poly, Team 10-55, Amido Spring 2014
CPSU-AMIDO-S14S10G55
4 Members
168 Guides authored
1 Guide Comment
I’ve done this about a million times. :)
Martin Hurley - Reply Share
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 127
All Time: 3,273
