Up to 20% off select tools
Sony NEX-5T Motherboard
Views: 2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
20
Past 30 Days:
120
All Time:
1,956
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The motherboard is the brains of the camera. Replacing the motherboard requires completely opening up the camera.
    1. Sony NEX-5T  Motherboard, Battery: step 1, image 1 of 1
      • Open the battery compartment by sliding the lock to the right.
      Ask FixBot
    2. Sony NEX-5T  Motherboard: step 2, image 1 of 1
      • Push in the blue lever.
      • The battery is on a spring so make sure you have control over it, or it might fly out.
      Ask FixBot
    3. Sony NEX-5T  Motherboard: step 3, image 1 of 2 Sony NEX-5T  Motherboard: step 3, image 2 of 2
      • Pull the battery out.
      Ask FixBot
    1. Sony NEX-5T  Motherboard, SD Card: step 4, image 1 of 3 Sony NEX-5T  Motherboard, SD Card: step 4, image 2 of 3 Sony NEX-5T  Motherboard, SD Card: step 4, image 3 of 3
      • Make sure to turn the cameras power switch to off before beginning this step.
      • Begin by holding the camera upside down with the bottom facing you. Identify the housing for the SD card, and battery.
      • You will use your other hand to slide the lock switch to this housing to the right. This will release the cap, allow it to come upwards.
      Ask FixBot
    2. Sony NEX-5T  Motherboard: step 5, image 1 of 3 Sony NEX-5T  Motherboard: step 5, image 2 of 3 Sony NEX-5T  Motherboard: step 5, image 3 of 3
      • Now that the cap to the battery and SD card housing is open, the SD card is visible.
      • You will need to press down on the SD card until you hear a click. Release the SD card and it will now be available to remove.
      • Grip the SD card and pull it out of the SD card slot.
      Ask FixBot
    3. Sony NEX-5T  Motherboard: step 6, image 1 of 3 Sony NEX-5T  Motherboard: step 6, image 2 of 3 Sony NEX-5T  Motherboard: step 6, image 3 of 3
      • To reinsert the SD card place it in its housing.
      • You will then need to push down on the SD card until you hear a click.
      • To ensure the SD card is in place you can visually inspect it. The SD card should be flush with the housing.
      Ask FixBot
    4. Sony NEX-5T  Motherboard: step 7, image 1 of 3 Sony NEX-5T  Motherboard: step 7, image 2 of 3 Sony NEX-5T  Motherboard: step 7, image 3 of 3
      • You may now close the housing for the SD card and battery.
      • Close the cap and while holding it down slide the locking tab to the left. This step should lock the cap in place.
      • Your SD card is now safely in place and you may turn your device on.
      Ask FixBot
    1. Sony NEX-5T  Motherboard, Motherboard: step 8, image 1 of 1
      • Remove the 3.5 mm exterior-side screw.
      Ask FixBot
    2. Sony NEX-5T  Motherboard: step 9, image 1 of 1
      • Remove the 3.5 mm bottom screw from the battery compartment.
      Ask FixBot
    3. Sony NEX-5T  Motherboard: step 10, image 1 of 1
      • Pry off the front-side cover with the small plastic spudger.
      • There is a adhesive holding the front-side cover to the camera frame, so more force may be necessary to remove it. Be careful as to not break the cover while prying.
      Ask FixBot
    4. Sony NEX-5T  Motherboard: step 11, image 1 of 1
      • Remove the 3.5 mm bottom screws.
      Ask FixBot
    5. Sony NEX-5T  Motherboard: step 12, image 1 of 2 Sony NEX-5T  Motherboard: step 12, image 2 of 2
      • Open the USB cover on the side of the camera.
      • Remove the 3.5 mm USB side screws.
      Ask FixBot
    6. Sony NEX-5T  Motherboard: step 13, image 1 of 1
      • Remove the 4mm screws at the back of the battery compartment.
      Ask FixBot
    7. Sony NEX-5T  Motherboard: step 14, image 1 of 1
      • Remove the 3.5 mm top flash-mount screw.
      Ask FixBot
    8. Sony NEX-5T  Motherboard: step 15, image 1 of 1
      • Flip the screen up.
      • Pry the top cover off with the small plastic spudger.
      Ask FixBot
    9. Sony NEX-5T  Motherboard: step 16, image 1 of 2 Sony NEX-5T  Motherboard: step 16, image 2 of 2
      • Pry the top part rear cover off with plastic spudger.
      • Flip the camera so the sensor faces down and push up on the rear cover from the battery compartment.
      Ask FixBot
    10. Sony NEX-5T  Motherboard: step 17, image 1 of 1
      • Remove the 2.25 mm tripod mount screws.
      Ask FixBot
    11. Sony NEX-5T  Motherboard: step 18, image 1 of 2 Sony NEX-5T  Motherboard: step 18, image 2 of 2
      • Remove the 2.25 mm side lanyard mount screw.
      • Pull the lanyard mount to remove.
      Ask FixBot
    12. Sony NEX-5T  Motherboard: step 19, image 1 of 1
      • Remove the 2.25 mm screws from the top.
      Ask FixBot
    13. Sony NEX-5T  Motherboard: step 20, image 1 of 1
      Tool used on this step:
      Buy
      • Using the tweezers, pull out the rubber grommet.
      • There is nothing holding the grommet in other than friction.
      • The grommet is small, don't lose it.
      Ask FixBot
    14. Sony NEX-5T  Motherboard: step 21, image 1 of 1
      • Pull the lead that was under the grommet out from the frame.
      Ask FixBot
    15. Sony NEX-5T  Motherboard: step 22, image 1 of 2 Sony NEX-5T  Motherboard: step 22, image 2 of 2
      • Flip the rotary selector and controls up over the top.
      • Holding the controls in place, pull the two frame pieces apart.
      • There is a connection between the motherboard and the LCD screen still attached to both halves, so don't pull to hard.
      Ask FixBot
    16. Sony NEX-5T  Motherboard: step 23, image 1 of 1
      • Disconnect the connection between the motherboard and LCD screen by pulling out the connector in the direction of the arrow.
      Ask FixBot
    17. Sony NEX-5T  Motherboard: step 24, image 1 of 2 Sony NEX-5T  Motherboard: step 24, image 2 of 2
      • Using the tweezers, disconnect the metal lead at the top of the motherboard by pulling up.
      Ask FixBot
    18. Sony NEX-5T  Motherboard: step 25, image 1 of 3 Sony NEX-5T  Motherboard: step 25, image 2 of 3 Sony NEX-5T  Motherboard: step 25, image 3 of 3
      • Disconnect the two top-right connectors by pulling them up towards the top.
      Ask FixBot
    19. Sony NEX-5T  Motherboard: step 26, image 1 of 2 Sony NEX-5T  Motherboard: step 26, image 2 of 2
      • Disconnect the two connectors on the right by pulling them to the right.
      Ask FixBot
    20. Sony NEX-5T  Motherboard: step 27, image 1 of 2 Sony NEX-5T  Motherboard: step 27, image 2 of 2
      • Using the tweezers, flip open the black door on the large connector on the bottom.
      • Remove the connector by pulling it away from the motherboard.
      Ask FixBot
    21. Sony NEX-5T  Motherboard: step 28, image 1 of 2 Sony NEX-5T  Motherboard: step 28, image 2 of 2
      • Using the tweezers, flip open the door on the smaller connector.
      • This is the same process for from the previous step.
      Ask FixBot
    22. Sony NEX-5T  Motherboard: step 29, image 1 of 2 Sony NEX-5T  Motherboard: step 29, image 2 of 2
      • Disconnect the connector that goes through the motherboard.
      • There is no door on this connector.
      Ask FixBot
    23. Sony NEX-5T  Motherboard: step 30, image 1 of 1
      • Remove the 4 mm screws securing the motherboard to the frame.
      Ask FixBot
    24. Sony NEX-5T  Motherboard: step 31, image 1 of 2 Sony NEX-5T  Motherboard: step 31, image 2 of 2
      • With the tweezers, remove the metal speaker cover.
      • Pull the speaker out of the frame.
      • Remember how the wires lay back in the frame for reassembly.
      Ask FixBot
    25. Sony NEX-5T  Motherboard: step 32, image 1 of 1
      • Flip the motherboard up and disconnect the connector on the back.
      • Seperate the motherboard from the frame.
      Ask FixBot
Author
with
William Kleinman
301 Reputation
3 Guides authored
USF Tampa, Team S13-G2, Cagle Spring 2017 Member of USF Tampa, Team S13-G2, Cagle Spring 2017
USFT-CAGLE-S17S13G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 120
All Time: 1,956
