Up to 20% off select tools
Sony NEX-5R Top Panel Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
103
All Time:
3,635
Comments: 8
7 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The removal of the top panel involves the removal of the front case to be able to reach the screws necessary for the removal of the top panel.
    1. Sony NEX-5R Top Panel Replacement, Front Case: step 1, image 1 of 2 Sony NEX-5R Top Panel Replacement, Front Case: step 1, image 2 of 2
      • Open the battery pack door by moving the slider to "OPEN".
      • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
      Ask FixBot
    2. Sony NEX-5R Top Panel Replacement: step 2, image 1 of 1
      • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
      Ask FixBot
    3. Sony NEX-5R Top Panel Replacement: step 3, image 1 of 2 Sony NEX-5R Top Panel Replacement: step 3, image 2 of 2
      • Use the spudger to raise the corner of the case from the camera.
      • One component of the front case should now be separate from the camera.
      Ask FixBot
    1. Sony NEX-5R Top Panel Replacement, Rear Case: step 4, image 1 of 1
      • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
      Ask FixBot
    2. Sony NEX-5R Top Panel Replacement: step 5, image 1 of 1
      • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
      Ask FixBot
    3. Sony NEX-5R Top Panel Replacement: step 6, image 1 of 1
      • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
      Ask FixBot
    4. Sony NEX-5R Top Panel Replacement: step 7, image 1 of 1
      • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
      Ask FixBot
    5. Sony NEX-5R Top Panel Replacement: step 8, image 1 of 2 Sony NEX-5R Top Panel Replacement: step 8, image 2 of 2
      • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
      • The back frame is fragile, so use the spudger gently.
      Ask FixBot
    6. Sony NEX-5R Top Panel Replacement: step 9, image 1 of 1
      • The back case should now be removed and look like this.
      Ask FixBot
    1. Sony NEX-5R Top Panel Replacement, Top Panel: step 10, image 1 of 1
      • Remove the 3.5mm phillips head screw underneath the flash port
      Ask FixBot
    2. Sony NEX-5R Top Panel Replacement: step 11, image 1 of 1
      • Remove the 3.5mm phillips head screw on the top left of the camera.
      Ask FixBot
    3. Sony NEX-5R Top Panel Replacement: step 12, image 1 of 1
      • Use the spudger tool to go around the seam of the top panel. The top should easily lift off.
      Ask FixBot
    4. Sony NEX-5R Top Panel Replacement: step 13, image 1 of 2 Sony NEX-5R Top Panel Replacement: step 13, image 2 of 2
      • This is what the camera and top panel should look like after you have completed the guide
      Ask FixBot
Author
with
Steven Fronczak
328 Reputation
1 Guide authored
Cal Poly, Team 8-9, Regan Spring 2014 Member of Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Members
84 Guides authored
1 Guide Comment
Hey Steven! This is all wrong! That's not the wright order: actually the top panel is the first part that can be removed, you don't need to tear down the rear panel and the front handgrip.. (it also may cause the damage of the rear panel!).
So, in order to remove the top panel just follow this order:
STEP 2
STEP 5 (Just the upper screw (not that one between HDMI and USB port)
STEP 6 (Just the two 4mm screws)
STEP 10
STEP 12
Its a lot easier ;)
Daniele
Daniele Fior - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 103
All Time: 3,635
