Introduction
Go to step 1 ↓The replacement of the rear casing requires removal of multiple screws around the entire camera and inside the battery pack. Once the fasteners are removed, you can carefully pry off the rear case.
Tools
Spudger4.9
Open the battery pack door by moving the slider to "OPEN".
Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
