Up to 20% off select tools
Sony NEX-5R Main Navigation Button Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
128
All Time:
5,449
Comments: 7
7 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The removal of the main navigation button involves removing the rear casing and carefully prying off the button as to not damage the sensitive components.
    1. Sony NEX-5R Main Navigation Button Replacement, Rear Case: step 1, image 1 of 1
      • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
      Ask FixBot
    2. Sony NEX-5R Main Navigation Button Replacement: step 2, image 1 of 1
      • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
      Ask FixBot
    3. Sony NEX-5R Main Navigation Button Replacement: step 3, image 1 of 1
      • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
      Ask FixBot
    4. Sony NEX-5R Main Navigation Button Replacement: step 4, image 1 of 1
      • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
      Ask FixBot
    5. Sony NEX-5R Main Navigation Button Replacement: step 5, image 1 of 2 Sony NEX-5R Main Navigation Button Replacement: step 5, image 2 of 2
      • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
      • The back frame is fragile, so use the spudger gently.
      Ask FixBot
    6. Sony NEX-5R Main Navigation Button Replacement: step 6, image 1 of 1
      • The back case should now be removed and look like this.
      Ask FixBot
    1. Sony NEX-5R Main Navigation Button Replacement, Main Navigation Button: step 7, image 1 of 1
      • Use spudger to pull the lead out from its housing.
      Ask FixBot
    2. Sony NEX-5R Main Navigation Button Replacement: step 8, image 1 of 2 Sony NEX-5R Main Navigation Button Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Squeeze the lead with the tweezers and hold the lead teeth tightly with your fingers. Pull straight out to disconnect.
      Ask FixBot
    3. Sony NEX-5R Main Navigation Button Replacement: step 9, image 1 of 2 Sony NEX-5R Main Navigation Button Replacement: step 9, image 2 of 2
      • The navigation button component should now be separate and able to be replaced with new component. The camera and navigation button should appear as shown.
      Ask FixBot
3 other people completed this guide.
Author
with
Emily Trujillo
1,153 Reputation
6 Guides authored
Cal Poly, Team 8-9, Regan Spring 2014 Member of Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 128
All Time: 5,449
