Sony NEX-5R LCD Screen Replacement
Views: 22K
View statistics:
Past 24 Hours:
6
Past 7 Days:
39
Past 30 Days:
208
All Time:
21,610
Comments: 21
7 comments on steps, 14 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Perhaps your LCD screen is scratched or damaged and needs replacing. This guide gives you directions on how to remove your LCD screen safely without damaging any of the device's sensitive components.
Tools
    1. Sony NEX-5R LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 Sony NEX-5R LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
      • Rotate screen to upper vertical position.
      • Remove the 8 (1.0 mm) black screws from the screen backing with Phillips screwdriver.
      • Make sure to keep track of these 8 screws. They are very small and easy to get lost.
      Ask FixBot
    2. Sony NEX-5R LCD Screen Replacement: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Remove black plate with tweezers. (Be careful not to lose the small square magnet sticking to the underside. It allows the auto rotation of the screen for selfies.)
      Ask FixBot
    3. Sony NEX-5R LCD Screen Replacement: step 3, image 1 of 1
      • Remove the second black metal plate covering with tweezers.
      • Be careful with this plate, its shape makes it delicate.
      Ask FixBot
    4. Sony NEX-5R LCD Screen Replacement: step 4, image 1 of 3 Sony NEX-5R LCD Screen Replacement: step 4, image 2 of 3 Sony NEX-5R LCD Screen Replacement: step 4, image 3 of 3
      • After removing both plates, remove the 2 (1.75 mm) Phillips screws on the bottom of the LCD screen.
      • Take off the 2 metal sliding side components. This will allow for us to slide off the screen.
      Ask FixBot
    5. Sony NEX-5R LCD Screen Replacement: step 5, image 1 of 1
      • Remove the blue square film covering the teal chip.
      Ask FixBot
    6. Sony NEX-5R LCD Screen Replacement: step 6, image 1 of 1
      • Lift the screen away from the backing.
      Ask FixBot
    7. Sony NEX-5R LCD Screen Replacement: step 7, image 1 of 2 Sony NEX-5R LCD Screen Replacement: step 7, image 2 of 2
      • Peel away the large rectangular black sheet with the tweezers.
      • Rotate the sheet so it is to the opposite side of the screen.
      Ask FixBot
    8. Sony NEX-5R LCD Screen Replacement: step 8, image 1 of 1
      • Using the tweezers, gently pull the small orange tab away from the backing.
      • The orange taping is very fragile, so make sure not to tear it with the tweezers or rip it out of its socket.
      Ask FixBot
    9. Sony NEX-5R LCD Screen Replacement: step 9, image 1 of 3 Sony NEX-5R LCD Screen Replacement: step 9, image 2 of 3 Sony NEX-5R LCD Screen Replacement: step 9, image 3 of 3
      • Use a spudger or plastic opening tool to flip the black locking tab up. Slide the cable straight out of its socket and remove the display.
      Ask FixBot
    10. Sony NEX-5R LCD Screen Replacement: step 10, image 1 of 1
      • Some replacement LCD screens do not come with the plastic frame. The original frame is easily separated and reused. Push the LDC out of the frame from behind. This takes some force. Be careful not to break the frame.
      • After separation, removed the sticky material between them and replaced it with double sided tape.
      • On reassembly stick strips of the tape to the inside edges of the plastic frame and then trimmed them to fit with a Exacto knife.
      • The small flexible cable must be folded around the inside edge of the plastic frame and then folded again to meet the connector. Follow the folds of the original cable.
      Ask FixBot
12 other people completed this guide.
Emily Trujillo
1,153 Reputation
6 Guides authored
Cal Poly, Team 8-9, Regan Spring 2014 Member of Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Members
84 Guides authored
14 Guide Comments
Success! This guide was very helpful. Here is a bit more info:
The LCD screen I ordered did not have the plastic frame. The original frame is easily separated. Push the LDC out of the frame from behind. This takes some force. Be careful not to break the frame. After separation, I removed the sticky material between them and replaced it with double sided tape. I first stuck strips of the tape to the inside edges of the plastic frame and then trimmed them to fit with a Exacto knife. The small flexible cable must be folded around the inside edge of the plastic frame and then folded again to meet the connector. Follow the folds of the original cable.
On reassembly I used a very tiny bit of double sided tape on each of the side rails, near the screw holes to hold them in place while putting on the outer most screen backing shown in step 6. When replacing this part pay special attention to the two small tabs at the bottom which must slide into slots at the bottom of the screen assembly.
Joseph Coffland - Reply Share
Where can I buy the screen other than bidding on ebay
oscarpatriciorojas - Reply Share
I purchased my NEX-5 replacement screen from e-Bay 'buy it now' from seller: szdigital2013. It came from China and cost a mere £10.29 inc.post.
Michael Sept.2017
michaelgamble61 - Reply Share
I see it amazon but is too damned expensive 60 ,79
double sided tape did not work for me. The screen keeps popping out - what kind of glue would you suggest?
Ben - Reply Share
Past 24 Hours: 6
Past 7 Days: 39
Past 30 Days: 208
All Time: 21,610
