Up to 20% off select tools
Sony NEX-5R Front Case Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
118
All Time:
3,222
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
We will be teaching you the proper way to disassemble your Sony NEX-5R so that you can replace your front case. This will be helpful to those that have damaged the front case and are looking to fix it by themselves.
    1. Sony NEX-5R Front Case Replacement, Front Case: step 1, image 1 of 2 Sony NEX-5R Front Case Replacement, Front Case: step 1, image 2 of 2
      • Open the battery pack door by moving the slider to "OPEN".
      • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
      Ask FixBot
    2. Sony NEX-5R Front Case Replacement: step 2, image 1 of 1
      • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
      Ask FixBot
    3. Sony NEX-5R Front Case Replacement: step 3, image 1 of 2 Sony NEX-5R Front Case Replacement: step 3, image 2 of 2
      • Use the spudger to raise the corner of the case from the camera.
      • One component of the front case should now be separate from the camera.
      Ask FixBot
4 other people completed this guide.
Author
with
Emily Trujillo
1,153 Reputation
6 Guides authored
Cal Poly, Team 8-9, Regan Spring 2014 Member of Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Members
84 Guides authored
1 Guide Comment
Can anybody tell me where I can purchase the replacement part used in this video - Regards
Chris
Chris Brookes - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 118
All Time: 3,222
