Sony ICF-P26 Antenna Replacement
    1. Sony ICF-P26 Antenna Replacement, Antenna: step 1, image 1 of 2 Sony ICF-P26 Antenna Replacement, Antenna: step 1, image 2 of 2
      • Power off and disconnect the radio from any power source.
      Ask FixBot
    2. Sony ICF-P26 Antenna Replacement: step 2, image 1 of 3 Sony ICF-P26 Antenna Replacement: step 2, image 2 of 3 Sony ICF-P26 Antenna Replacement: step 2, image 3 of 3
      • Use a mini screwdriver to remove the two screws from the battery compartment.
      • Gently insert an opening tool where the FM/AM/Off switch is, to force your way up.
      • Insert the opening tool in the other side where the volume and the earphone go.
      • You will hear hinges pop open.
      Ask FixBot
    3. Sony ICF-P26 Antenna Replacement: step 3, image 1 of 3 Sony ICF-P26 Antenna Replacement: step 3, image 2 of 3 Sony ICF-P26 Antenna Replacement: step 3, image 3 of 3
      • Use the mini screwdriver to remove the screw holding the motherboard.
      • Unscrew the damaged antenna.
      Ask FixBot
    4. Sony ICF-P26 Antenna Replacement: step 4, image 1 of 3 Sony ICF-P26 Antenna Replacement: step 4, image 2 of 3 Sony ICF-P26 Antenna Replacement: step 4, image 3 of 3
      • Use the mini screwdriver to replace the new antenna.
      Ask FixBot
    5. Sony ICF-P26 Antenna Replacement: step 5, image 1 of 2 Sony ICF-P26 Antenna Replacement: step 5, image 2 of 2
      • Use the mini screwdriver to assemble the motherboard.
      Ask FixBot
    6. Sony ICF-P26 Antenna Replacement: step 6, image 1 of 3 Sony ICF-P26 Antenna Replacement: step 6, image 2 of 3 Sony ICF-P26 Antenna Replacement: step 6, image 3 of 3
      • Use the mini screwdriver to assemble the cover.
      • Insert the batteries.
      Ask FixBot
    7. Sony ICF-P26 Antenna Replacement: step 7, image 1 of 2 Sony ICF-P26 Antenna Replacement: step 7, image 2 of 2
      • Switch on the radio.
      Ask FixBot
Finish Line
5 other people completed this guide.
Olaloye Thontteh
280 Reputation
1 Guide authored
2 Guide Comments
Where would one acquire a compatible replacement antenna for this model of radio?
Mason Smith - Reply Share
Thank you so much. The difficulty is opening the case. You explained it very well. My problem was the dirty potentiometer. I simply poured enough isopropyl alcool on it, to "wash" it, it flowed inside, turn it few times, that was all. Works as new. Thank you.
Jean-Yves Béguec - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 89
All Time: 5,533
