Up to 20% off select tools
Sony ICF-CS15iP Disassembly
Views: 1.8K
View statistics:
Past 24 Hours:
7
Past 7 Days:
21
Past 30 Days:
128
All Time:
1,785
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes - 3 hours
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This is a complete tear down of the Sony ICF-CS15iP
Featured Document
Preview of the first page of this document
42867221M
Log in to view the full document
Log In
    1. Sony ICF-CS15iP Disassembly, Remove all 18 screws from the device’s outer shell.: step 1, image 1 of 2 Sony ICF-CS15iP Disassembly, Remove all 18 screws from the device’s outer shell.: step 1, image 2 of 2
      • All of these damned screws are approx. a PH1 size.
      Ask FixBot
    2. Sony ICF-CS15iP Disassembly, Remove back and base covers.: step 2, image 1 of 3 Sony ICF-CS15iP Disassembly, Remove back and base covers.: step 2, image 2 of 3 Sony ICF-CS15iP Disassembly, Remove back and base covers.: step 2, image 3 of 3
      • Pull on the back to ease it off, and there will be some wires that will need to be disconnected. (Green circled wire not necessary to remove but recommended)
      Ask FixBot
    3. Sony ICF-CS15iP Disassembly, Remove power and antenna board.: step 3, image 1 of 1
      • Unfasten the 4 screws holding in the board.
      Ask FixBot
    4. Sony ICF-CS15iP Disassembly, Remove display.: step 4, image 1 of 2 Sony ICF-CS15iP Disassembly, Remove display.: step 4, image 2 of 2
      • Remove the following screws:
      Ask FixBot
    5. Sony ICF-CS15iP Disassembly, Remove dock: step 5, image 1 of 1
      • Remove the following screws and be careful with the dock connector, as it has springs that can fly to oblivion.
      Ask FixBot
    6. Sony ICF-CS15iP Disassembly, Remove speaker assembly.: step 6, image 1 of 1
      Ask FixBot
    7. Sony ICF-CS15iP Disassembly, Take a break (optional): step 7, image 1 of 1
      • I chose to eat pretzels, you can have a 10 course meal prepared by Gordon Ramsay
      Ask FixBot
    8. Sony ICF-CS15iP Disassembly, Remove speakers.: step 8, image 1 of 1
      • These are some good 4 ohm 5 watt speakers.
      Ask FixBot
    9. Sony ICF-CS15iP Disassembly, Remove top buttons.: step 9, image 1 of 1
      • My specific board has some damage from the previous owner, and I only made it worse lol.
      Ask FixBot
    10. Sony ICF-CS15iP Disassembly, Remove rear buttons.: step 10, image 1 of 1
      • This is definitely all the screws that need to be unfastened.
      Ask FixBot
      • I used a PH1 and PH0 screwdriver.
      Ask FixBot
Attached Documents
Author
with
Adrian Lopez
527 Reputation
3 Guides authored
2 Guide Comments
Buen día y muchas gracias por tomarse el tiempo de documentar el proceso de desarmar un CS15iPN. Tengo una pregunta por favor: ¿Cómo pudo desconectar los ribbons (que se observan en la foto del paso 4) de sus conectores en la tarjeta? Yo desarmé mi equipo y no me atreví a desconectar los ribbons porque me parecía que estaban "soldados" permanentemente en los conectores.
Luis - Reply Share
I disconnected them by just pulling the cables out gently by the blue tab. Take your time and be careful.
Los desconecté simplemente tirando de los cables con cuidado por la pestaña azul. Tómate tu tiempo y ten cuidado.
Adrian Lopez - Reply Share
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 128
All Time: 1,785
