Sony ICF-C1iPMK2 Screen Replacement
    1. Sony ICF-C1iPMK2 Screen Replacement, Screen: step 1, image 1 of 3 Sony ICF-C1iPMK2 Screen Replacement, Screen: step 1, image 2 of 3 Sony ICF-C1iPMK2 Screen Replacement, Screen: step 1, image 3 of 3
      • Flip product over to see the back.
      • Remove the 1 cm Phillips #00 screws.
      • Use a plastic spudger to pry the back chassis off of the front.
      Ask FixBot
    2. Sony ICF-C1iPMK2 Screen Replacement: step 2, image 1 of 3 Sony ICF-C1iPMK2 Screen Replacement: step 2, image 2 of 3 Sony ICF-C1iPMK2 Screen Replacement: step 2, image 3 of 3
      • This step contains ribbon cables. Be careful to not bend or rip these fragile cables, to protect your device.
      • Open up the back.
      • Carefully remove the ribbon cables by pulling them straight out of the port.
      Ask FixBot
    3. Sony ICF-C1iPMK2 Screen Replacement: step 3, image 1 of 2 Sony ICF-C1iPMK2 Screen Replacement: step 3, image 2 of 2
      • Remove the power connector.
      • Remove the aux cable connector.
      Ask FixBot
    4. Sony ICF-C1iPMK2 Screen Replacement: step 4, image 1 of 1
      • Slide buttons off the front chassis
      Ask FixBot
    5. Sony ICF-C1iPMK2 Screen Replacement: step 5, image 1 of 3 Sony ICF-C1iPMK2 Screen Replacement: step 5, image 2 of 3 Sony ICF-C1iPMK2 Screen Replacement: step 5, image 3 of 3
      • Remove the 1 cm screws from the plastic speaker cover using Phillips #00 screwdriver.
      • Gently pull the speaker cable out.
      Ask FixBot
    6. Sony ICF-C1iPMK2 Screen Replacement: step 6, image 1 of 3 Sony ICF-C1iPMK2 Screen Replacement: step 6, image 2 of 3 Sony ICF-C1iPMK2 Screen Replacement: step 6, image 3 of 3
      • Remove the plastic speaker cover from the left side.
      Ask FixBot
    7. Sony ICF-C1iPMK2 Screen Replacement: step 7, image 1 of 3 Sony ICF-C1iPMK2 Screen Replacement: step 7, image 2 of 3 Sony ICF-C1iPMK2 Screen Replacement: step 7, image 3 of 3
      • Remove the two 1 cm Phillips #00 screws.
      • Carefully pull out the ribbon cable.
      • Slide the iPod dock out.
      Ask FixBot
    8. Sony ICF-C1iPMK2 Screen Replacement: step 8, image 1 of 1
      • Gently push down and pull the screen out.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 676
