Up to 20% off select tools
Sony ICF-C1T Screen Replacement
Views: 6.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
117
All Time:
6,100
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the screen of a Sony ICF-C1T. When your screen is too bright or it has a lot of scratches on it, you can easily replace the screen or add a sheet of tint to the backside of it.
    1. Sony ICF-C1T Screen Replacement, Screen: step 1, image 1 of 1
      • Make sure the clock is unplugged from the wall and the replacement battery has been taken out of the clock to prevent harm to you and to the clock.
      • Use a Phillips 00 head screwdriver to remove the four 14 mm screws from the bottom of the clock.
      Ask FixBot
    2. Sony ICF-C1T Screen Replacement: step 2, image 1 of 1
      • Insert the plastic opening tool to pry apart the top and sides of the device gently.
      Ask FixBot
    3. Sony ICF-C1T Screen Replacement: step 3, image 1 of 2 Sony ICF-C1T Screen Replacement: step 3, image 2 of 2
      • Carefully pull the top of clock off as the clock display is located directly behind the face plate and is still connected by multiple wires.
      • Pull the top of the device away from the rest of the clock to expose the inside.
      Ask FixBot
    4. Sony ICF-C1T Screen Replacement: step 4, image 1 of 2 Sony ICF-C1T Screen Replacement: step 4, image 2 of 2
      • Do not use too much pressure on the plastic to not break it.
      • Add pressure to the inside of the screen so that a small area is loosened enough to be able to use an opening tool.
      • Use the plastic opening tool to separate the screen from the device.
      Ask FixBot
    5. Sony ICF-C1T Screen Replacement: step 5, image 1 of 2 Sony ICF-C1T Screen Replacement: step 5, image 2 of 2
      • Apply a tinted spray to dim the brightness once the tinted sheet is out of the way.
      • Another way to solve the brightness problem is to apply a tinted color sheet protector.
      Ask FixBot
Author
with
amber woolery
307 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 117
All Time: 6,100
