Sony ICD-UX570 Battery Replacement
    1. Sony ICD-UX570 Battery Replacement, Remove the screw cover: step 1, image 1 of 3 Sony ICD-UX570 Battery Replacement, Remove the screw cover: step 1, image 2 of 3 Sony ICD-UX570 Battery Replacement, Remove the screw cover: step 1, image 3 of 3
      • Wedge a thin and pointy tool (I used a knife) under the screw cover and pry it open.
      Ask FixBot
    2. Sony ICD-UX570 Battery Replacement, Remove screws: step 2, image 1 of 2 Sony ICD-UX570 Battery Replacement, Remove screws: step 2, image 2 of 2
      • 2x Phillips #0
      Ask FixBot
    3. Sony ICD-UX570 Battery Replacement: step 3, image 1 of 3 Sony ICD-UX570 Battery Replacement: step 3, image 2 of 3 Sony ICD-UX570 Battery Replacement: step 3, image 3 of 3
      • I broke the yellow clip, I don't know if it's possible to keep it intact.
      • The green bit holds a metal tooth from the main case: at that point pull the back cover towards the top of the recorder.
      • Using a thin pry tool undo the back cover clips.
      • Start at the top and work your way around.
      • On the side with the USB connector slider there's a strong clip, I suspect at that point you have to pull up towards the top of the recorder. I broke off mine trying but it doesn't show once closed.
      Ask FixBot
    4. Sony ICD-UX570 Battery Replacement: step 4, image 1 of 3 Sony ICD-UX570 Battery Replacement: step 4, image 2 of 3 Sony ICD-UX570 Battery Replacement: step 4, image 3 of 3
      • Pull up the battery with a pry tool, making sure not to pierce it. It's held down with a bit of double sided tape.
      • Desolder the wires and install the new battery.
      Ask FixBot
2 other people completed this guide.
Ugo
163 Reputation
1 Guide authored
7 Guide Comments
Thank you for the great instructions! I just replaced my battery and the new one is charging. The instructions were clear and simple to follow. I am not electrically inclined at all, but this was easy. Instead of soldering, I cut the wires from the old battery near the battery terminal so I had wire to work with. I then tied the new wires to the old ones and used electrical tape. I've never soldered before, so this was an easy alternative. Thank you again!
Steven Laser - Reply Share
Good thinking. Glad to hear it was useful!
Ugo - Reply Share
May i ask how did you tie the wires. I don't know how to solder so this method sounds good, but I'm afraid I might fry something by touching it wrong lol
SKUNT - Reply Share
Sir please play a video for bty replacement
Kuldeep Singh Dabas - Reply Share
does anyone have advice for a ux 560?
Eliezer Spira - Reply Share
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 197
All Time: 5,365
