Sony Handycam HDR-CX675 Camera Shell Replacement
    1. Sony Handycam HDR-CX675 Camera Shell Replacement, Camera Shell: step 1, image 1 of 1
      • The battery should be removed and oriented upwards.
      Ask FixBot
    2. Sony Handycam HDR-CX675 Camera Shell Replacement: step 2, image 1 of 1
      • Remove the side 4.5 mm JIS #00 screw using JIS Screwdriver
      • Remove the 5.5 mm JIS #00 screw.
      Ask FixBot
    3. Sony Handycam HDR-CX675 Camera Shell Replacement: step 3, image 1 of 2 Sony Handycam HDR-CX675 Camera Shell Replacement: step 3, image 2 of 2
      • Gently pry the plastic case surrounding the start/stop button free by using the blue plastic opening tools.
      • Remove the casing using your thumb and index finger.
      Ask FixBot
    4. Sony Handycam HDR-CX675 Camera Shell Replacement: step 4, image 1 of 1
      • Turn the camera around and flip open the LCD screen to expose the side panel.
      • Remove the 5.5mm #00 screw using the J00 head screwdriver.
      Ask FixBot
    5. Sony Handycam HDR-CX675 Camera Shell Replacement: step 5, image 1 of 1
      • Turn the camera to the handgrip side and unscrew two of the 5.5mm JIS #00 head screws using the JIS #00 head screwdriver.
      Ask FixBot
    6. Sony Handycam HDR-CX675 Camera Shell Replacement: step 6, image 1 of 1
      • Remove the two 5.5mm JIS #00 screws with the bottom of the camera facing up.
      Ask FixBot
    7. Sony Handycam HDR-CX675 Camera Shell Replacement: step 7, image 1 of 1
      • Turn the camera around in a way that the bottom of the camera is facing you.
      • Use the blue opening tool to gently remove the camera shell off of the camera.
      Ask FixBot
5 other people completed this guide.
Mohamed Nazer
421 Reputation
3 Guides authored
USF Tampa, Team 8-2, Eyestone Spring 2017 Member of USF Tampa, Team 8-2, Eyestone Spring 2017
USFT-EYESTONE-S17S8G2
3 Members
48 Guides authored
2 Guide Comments
Display Sony camera
Rupesh kumar - Reply Share
Sony camera display
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 41
All Time: 1,586
